why do cars with alarms/remote starts always start easier?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOMO »</TD></TR><TR><TD CLASS="quote">so ive noticed...you hear *beep beep* they turn the key and a one click start..does a remote start tap into the ignition/fiel system to ensure a quicker start?
All remote starts do it literally trick the car into thinking that you are turning the key inside the car, and tach wires tell the brain to stop cranking because the car is running...
</TD></TR></TABLE>All remote starts do it literally trick the car into thinking that you are turning the key inside the car, and tach wires tell the brain to stop cranking because the car is running...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg »</TD></TR><TR><TD CLASS="quote">You are thinking too much. </TD></TR></TABLE>
LOL.
Hondas are famous for good starts.
Technically, a remote starter should be able to start your car better than you. not by much though...
LOL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOMO »</TD></TR><TR><TD CLASS="quote">cool...i guess i should ask in tech what i can do to get a first click start...
um.. ive installed MANY remote starters on hondas before.. its CAKE.. as for starting on the first click, good luck, the starter has to turn the flywheel to start the motor, if the it doesnt turn it enough then the car will not start..
</TD></TR></TABLE>um.. ive installed MANY remote starters on hondas before.. its CAKE.. as for starting on the first click, good luck, the starter has to turn the flywheel to start the motor, if the it doesnt turn it enough then the car will not start..
myaccord2004
Feb 9, 2018 02:12 PM
