Brake Swap - 93 Prelude Rotors and Type R Calipers
Old Jun 10, 2003 | 04:39 PM
ogawa_jiei's Avatar
Default Brake Swap - 93 Prelude Rotors and Type R Calipers
Has anybody else out there with an EG done this? I heard it all bolts right on, but some have said you need the knuckle. According to what I've read on Hybrid Honda, it should just bolt on. Any information??? Thanks for your time.
Sincerely,
CDMEG
Old Jun 10, 2003 | 04:45 PM
BigZ88's Avatar
Default Re: Brake Swap - 93 Prelude Rotors and Type R Calipers (CDMEG)
it will probably work if you redrill the rotors to 4x100....or i think it will.. May need to shave the caliper or something too...dont remember
Old Jun 10, 2003 | 04:46 PM
ekHatchTDot's Avatar
Default Re: Brake Swap - 93 Prelude Rotors and Type R Calipers (BigZ88)
yup you gotta redrill the rotors to fit, other than that everything should be bolt on
Old Jun 10, 2003 | 04:51 PM
ogawa_jiei's Avatar
Default Re: Brake Swap - 93 Prelude Rotors and Type R Calipers (ekHatchTDot)
Thanks. That's what I remember also - you have to redrill the rotors. Aside from that I heard that it bolts in. The only thing I'm worried about is the calipers. As it stands now, those calipers will not fit inbetween the back of my stock disks and the mounting bracket. Do the prelude rotors have enough offset to sit out more, thereby giving up more space here? Just want to know before I go out and get the rotors and drill them, only to find out that there's no clearance. But I guess I can shave the calipers. Has anybody already done this swap?
Sincerely,
CDMEG
Old Jun 11, 2003 | 07:01 AM
Chilly Willy
Guest
Posts: n/a
bump for you... i want to know also. i bought a H22A engine with a suspension drop and i was wondering if the rotors and calipers will fit on mine to.
Old Jun 11, 2003 | 07:26 AM
PhucNguyen57's Avatar
Default Re: Brake Swap - 93 Prelude Rotors and Type R Calipers (Chilly *****)
https://honda-tech.com/zerothread?id=152884
Old Jun 12, 2003 | 11:31 AM
ogawa_jiei's Avatar
I have the rotors from a Prelude VTEC 93, Type R calipers, but no way to adapt it to my spindle and caliper brackets. I saw fastbrakes setup. Looks good. Has anyone used it on a 92 Civic CX (CDM)? I need to buy or make whatever it is that they use to adapt with.
dr_latino999
Suspension & Brakes
Mar 15, 2010 05:59 AM
dartdc97
Oct 10, 2006 12:05 PM
Understeer
May 1, 2006 07:20 PM
dc2gsr96
Mar 5, 2006 12:44 PM
rabvtec
Aug 1, 2003 06:20 PM
