compression result question
Old Jun 10, 2003 | 03:18 PM
Hcivic88's Avatar
Default compression result question
alright, my buddy just did a compression test on his 91 DX hatch auto.
1st cylinder, 180psi, 2nd 0psi, 3rd 180psi, 4th 180psi
The three cylinders were perfect, but 2nd cylinder had 0 compression.
any idea on what could be causing this? he's also getting some grey smoke out of the exhaust.
head gasket maybe?
Old Jun 10, 2003 | 03:21 PM
Malgerus's Avatar
Default Re: compression result question (Hcivic88)
Sounds like rings. Did you try pouring oil into that dead cylinder? If compression jumps... rings. Or it could be the valves aren't closing properly and not sealing right.
Old Jun 10, 2003 | 07:52 PM
znatural1's Avatar
I think you have burnt the exhaust valve in one cylinder.
Old Jun 10, 2003 | 07:56 PM
SIRX's Avatar
valves, rings, or blown head gasket. The only way to know for sure is to pull the head
Old Jun 10, 2003 | 08:15 PM
blah13's Avatar
Default Re: compression result question (SIRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX &raquo;</TD></TR><TR><TD CLASS="quote">valves, rings, or blown head gasket. The only way to know for sure is to pull the head</TD></TR></TABLE>
Leakdown test...
Old Jun 12, 2003 | 11:45 AM
Hcivic88's Avatar
Default Re: compression result question (blah13)
alright, i tried putting oil down the bad cylinder, and I got 20psi, so now I'm pretty sure that it must be the ring. all valves and everything looked fine to me. havn't pulled the head off yet, because I had to go home(1am and I had school in the morning) so ill have to wait a little bit before i can go back out to his house again. he has another engine, same thing sitting in his garage thats in almost perfect shape(needs little things like plugs, starter, intake... although we did get it started. so we're thinking we may just switch out the engines, cause we dont really have a lot of time to fool around with the engine, exams are coming up.
anyways, thanks everyone for your help, ive already pulled and dropped in a few engines so this should be nothing.
talk to ya later
Team_Coast978
Engine Management and Tuning
Jun 10, 2013 10:58 AM
infinkc
Honda S2000
Jan 16, 2013 08:11 PM
zerovandez
Oct 3, 2011 05:38 PM
Unjockable
16
Mar 29, 2005 08:41 PM
thehondaguru
Jun 24, 2003 07:41 AM
