toda with turbo??
Old Jul 19, 2001 | 08:50 AM
GSRacer's Avatar
New User
Default toda with turbo??
we have toda b cams installed on a b16. we are plannin on going turbo with this engine. will we have to switch back from the toda's or can i keep them in??
Old Jul 19, 2001 | 09:33 AM
sgT's Avatar
sgT
Default Re: toda with turbo?? (GSRacer)
try it. tell us what happens
Old Jul 19, 2001 | 12:57 PM
MugenDC2R's Avatar
The SIGNAL AUTO drag civic uses Toda spec A cams..... http://www.signalauto.com/chop2.html
Old Jul 19, 2001 | 01:59 PM
KekeK_5G's Avatar
try it, a friend of mine has spec B's in a turbo Gen 5 hybrid. He ran 11.8@121 at the track at 18 psi. GSR motor and tranny in an Si HB.
Old Jul 19, 2001 | 03:54 PM
MugenFormula1's Avatar
Default Re: toda with turbo?? (1flySi)
they`ll work, just need to get them on a dyno and dialed in.
Old Jul 20, 2001 | 05:06 PM
GSpeedR's Avatar
Default Re: toda with turbo?? (MugenFormula1)
I would think they would be more of a hindrance than an advantage.
If you have a high revving turbo and a BUILT block, you could probably lay down some serious power. But the extreme lift/duration specs of the B's would be kind of counterproductive, I would believe. Of course I know nothing about turbos.
Old Jul 20, 2001 | 07:57 PM
HXMan's Avatar
Default Re: toda with turbo?? (GSpeedR)
I would think the spec b's would have too much overlap for a turbo street motor.
Old Aug 7, 2001 | 07:38 AM
Black R's Avatar
25 Year Member
Default Re: toda with turbo?? (sgT)
hmmm...
That would be interesting - spec a's w/ sc... presuming you had the fuel and air sorted out...
Old Aug 7, 2001 | 02:44 PM
SpoonCivic's Avatar
New User
Default Re: toda with turbo?? (HXMan)
ditto..I heard u'll kill ur motor.
U can try Spoon, Spec A's, ITR's, CTR's, Top Fuel as these arent high lift cams...
They will garner much horespower compared to stock GSR cams...
lindseyhunt1090
Apr 23, 2016 11:06 PM
Jdmsoles
Honda S2000
Sep 19, 2006 06:35 AM
SiREF8
Sep 6, 2002 06:02 PM
MaD3 In JaPaN
Feb 18, 2002 03:48 PM
SpeedMonkeyRacing
Oct 21, 2001 02:04 PM
