How to remove stripped axle nut?
Old Jun 10, 2003 | 09:14 AM
RTW DC2R's Avatar
Default How to remove stripped axle nut?
Im pretty sure the nut that holds the left axle on the hub is stripped. I can turn it by hand (with a socket and wrench) both clockwise and counter clockwise, but it doesnt go on any tighter or come off. The axle shaft isnt spinning. I ordered new axles and need to get these off. Any ideas how to go about getting this thing off without causing more problems?
Old Jun 10, 2003 | 09:18 AM
AK94GSR's Avatar
Default Re: How to remove stripped axle nut? (RTW DC2)
Lots O Boost w/ an Impact Gun
Old Jun 10, 2003 | 09:40 AM
VTHokie's Avatar
well if you ordered new axles and you have no other alternative you can alway cut it off. I'd try the impact gun first, then if that doesn't work get one of those rotory tools which uses compressed air to cut it off.
Old Jun 10, 2003 | 10:05 AM
RTW DC2R's Avatar
Default Re: How to remove stripped axle nut? (VTHokie)
if its stripped, how is an impact gun gonna get it off? I can turn it by hand so its not like I need force behind it. Id like to try to avoid cutting it off but I will if thats a last resort. cutting stuff is fun
Old Jun 10, 2003 | 12:25 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">if its stripped, how is an impact gun gonna get it off? I can turn it by hand so its not like I need force behind it. Id like to try to avoid cutting it off but I will if thats a last resort. cutting stuff is fun </TD></TR></TABLE>
An impact works by delivering very short blasts of torque... sometimes this works. If not, get out yer cutting wheel
Old Jun 10, 2003 | 01:38 PM
owen_the_soyboy's Avatar
Default Re: How to remove stripped axle nut? (.RJ)
drill out a section of it with a 1/4" bit. then it should come right off by hand.
you may put a dimple on the axle's threads but its easier then cutting it off.
Old Jun 10, 2003 | 07:14 PM
Type S's Avatar
Default Re: How to remove stripped axle nut? (owen_the_soyboy)
i had the same thing happen to me. what i did was take a chisel and a heavy hammer. you have to cut into the nut with the chisel and then flatten the angle on the chisel and hit it with the hammer so that it will turn.
if you are confused : start like his to cut into the nut l_
then you flatten the angle to turn it /_
Old Jun 10, 2003 | 08:04 PM
RTW DC2R's Avatar
Default Re: How to remove stripped axle nut? (Type S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type S &raquo;</TD></TR><TR><TD CLASS="quote">i had the same thing happen to me. what i did was take a chisel and a heavy hammer. you have to cut into the nut with the chisel and then flatten the angle on the chisel and hit it with the hammer so that it will turn.
then you flatten the angle to turn it /_</TD></TR></TABLE>
Thanks, but I think you are mistaken on the actual problem. Im able to turn the nut with no problem. The problem appears to be that the threads that hold the nut on are stripped and I can turn the nut both directions but it doesnt loosen or tighten. My friend is gonna take care of it at his shop once I get the new axles so it should be ok since he will have access to all kinds of tools.
flaxx0r
28
Dec 29, 2008 07:15 AM
sirt_eg
Jun 11, 2007 03:02 AM
B18EG6
Apr 16, 2006 03:51 PM
Ladysman_civic
Sep 4, 2003 02:13 PM
tilt
Dec 9, 2002 09:24 PM
