OBD1 to OBD2 conversion harness
Old Jun 10, 2003 | 05:44 AM
514_type R's Avatar
Default OBD1 to OBD2 conversion harness
Id like to know if the conversion harness for the 1997-1999 type r is the same has the 2000-2001 harness?
If I have a 2001 harness, how can it fit the 1998 car?
thanks
Old Jun 10, 2003 | 07:23 AM
kenji's Avatar
25 Year Member
Default Re: OBD1 to OBD2 conversion harness (514_type R)
They are not the same. You will need to either make or buy another harness to allow it to fit in your car.
Email me if you are interested in a harness.
-kenji
Old Jun 10, 2003 | 07:32 AM
514_type R's Avatar
Default Re: OBD1 to OBD2 conversion harness (kenji)
actually kenji I wanted to purchace the harness to install you ecu p28 afterward. I need obd1 ecu to install my test pipe.
kenji, what is your e-mail
Old Jun 10, 2003 | 09:43 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 514_type R &raquo;</TD></TR><TR><TD CLASS="quote">actually kenji I wanted to purchace the harness to install you ecu p28 afterward. I need obd1 ecu to install my test pipe.
Why do you need an OBD 1 for a test pipe? The code obd 2 will throw means nothing if that is what you are worried about.
Old Jun 10, 2003 | 01:01 PM
Blown90hatcH's Avatar
kenji211@tampabay.rr.com
Old Jun 10, 2003 | 01:02 PM
Nameless RB26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">
Why do you need an OBD 1 for a test pipe? The code obd 2 will throw means nothing if that is what you are worried about.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 514_type R &raquo;</TD></TR><TR><TD CLASS="quote">actually kenji I wanted to purchace the harness to install you ecu p28 afterward. </TD></TR></TABLE>
"you p28" .. I think that means his chipped P28.
raffaelli
Oct 6, 2010 09:02 PM
silverboost
Jan 18, 2006 09:25 AM
quaker
Feb 20, 2004 12:24 PM
Malachi_
14
Sep 25, 2003 04:12 PM
