a/c question in 92 s
I test drove a car, and everything is fine with it. the only problem is.....the a/c isn't cold and no air comes out at all through the middle vents. i thought it would be a bad blower, but then again, if it was bad blower, then why would air still come out of the other vents? has anyone had this problem in their 4th gens? if so how did you fix? if not, what do you think it could be? is there any way that i can do something to see whats wrong instead of paying someone a shitload of money to tell me something i could have found out myself? thanks.
when you test drove the car did you make sure you had the a/c vent buttons pushed? The only time mine isnt working perfect is when i accidentally hit the buttons when cleaning which makes all the buttons turn off. then when you push a button it stops blocking the airflow. also if you want really cold a/c make sure you are using recirculated air and not fresh air.
PassportBreh
Mar 21, 2012 05:35 AM
edgaradelchi
25
Jun 24, 2011 10:53 PM
