EG8 Air conditioning problem
Re: EG8 Air conditioning problem
Assuming your condenser pump is still working, when was the last time it was recharged? Considering the car is anywhere from 25 to 28 years old, it probably needs it.
Take it to a professional. Don't get the DIY kit. There is no way to prevent contaminants that'll fry your system.
Beyond needing a recharge, have you checked to make sure your intake vent is not blocked with crud? IE does the heat blow with the same force as the cold?
A more clear description of the problem is needed.
Is this a vent air flow problem or an A/C problem?
Does the A/C work at all?
Is the heater possibly stuck on?
A stock 92 Civic uses old R12 rather than the more modern R134a refrigerant. Some shops can recharge R12 systems, though it's more expensive.
alscrx
10
01-03-2008 06:57 PM
