TOP LINE crank shafts????? anyone using one?
Old Jun 8, 2003 | 02:21 PM
Irishweird00's Avatar
Banned
Default TOP LINE crank shafts????? anyone using one?
Dunno, looking for a B17 crank and dont want to spend 700 on a new one from acura
Old Jun 8, 2003 | 02:23 PM
allmtr's Avatar
Default Re: TOP LINE crank shafts????? anyone using one? (Irishweird00)
im sure a custom or after market one will be just as much or more
Old Jun 8, 2003 | 02:24 PM
Banned
Default Re: TOP LINE crank shafts????? anyone using one? (allmtr)
400, thats why im asking
Edit, with bearings
Old Jun 8, 2003 | 02:27 PM
allmtr's Avatar
i assume this is going in a b16a, right?
Banned
correct
Old Jun 8, 2003 | 02:34 PM
allmtr's Avatar
to tell you the truth... ive heard this wasnt worth it cuz its not much of a difference. ive had a friend witha b17, and he regreted it. youd be one of the few running that settup. my friend has an ls crank in his b16a with custom pistons(shorter) an it such a sleeper. 85mm bore too. i would suggest that, but its up to u.
i dont know anything about those cranks though, i just know hondas cranks are top quality
Old Jun 8, 2003 | 02:40 PM
Banned
Yeah, it ups the displacement to 1595cc to 1678cc.... so couldnt be all that bad?? I don't want to deal with custom rods, plus the R/S of a ls crank in a b16 isnt to my liking... i dont wanna screw with that to much, to much custom work... I could buy a used one, but im worried about wear on the crank... high milage ect...
Old Jun 8, 2003 | 02:52 PM
allmtr's Avatar
just keep your b16 crank then. better r/s than the b17. 73 more cc of displacement isnt really that big of a diff.
the jun stroker kit uses an 89mm crank, same as an LS. it makes power. just dont rev it up too high too much.if you go strong enough rods and good bearings, it will be all good.
using the 400 dollors to up the compression will do more than that 1.7 crank.
LS-Rman
18
Feb 11, 2013 05:56 AM
mikesrex
18
May 31, 2010 06:33 PM
JDMkidGSR
Aug 18, 2004 04:15 PM
lsvtec hatch05
Nov 29, 2003 06:19 AM
TheSwift1
May 29, 2002 10:42 AM
