What rpm to launch. Need other peoples suggestions.
Hey people I am headed to the track tonight and just wanted others suggestions at what rpm I should launch at.
Last time at the track I posted a 13.7@102 launching around 3k rpm on drag radials. My question is do you guys think I should launch at a higher rpm than that or is that relatively good enough. thanks,
Nick
Nick
I know that much , just wanted to hear what others have launched at with turbos on there car using drag radials . I want to launch at about 4k but dont want to spin to much, due to the fact I may only get about 2 or 3 runs at max I don't want to experiment all that much. I have to drive almost 2 hours to get there and don't want to go home with a crappy timeslip
lower pressure to approx 15psi launch at aprrox 4500 and then drop it should net you around 2.0 60 ft work your pressure down througout the nite.
I was wonderin if u have a check engine because i had the same kit but mine is a 98 and i am getting a random misfire..will u tell me why?.what kind of plugs do u use and wher did u gap this at??? thanks
