My dyno
Old Jun 7, 2003 | 12:40 PM
Nata$'s Avatar
Default My dyno
Well first time at the dyno for the torqueless wonder B16. My set up: 92 civic cx hatch, b16 from 00 SI, I/H/E, Cam gears set at 0,-1, no FPR or SVCR. Big thanks to Vapor for doing a dyno day for us in Tampa Bay. Next I will work on fuel/air. Anything else do you recommend? Thanks!
Old Jun 7, 2003 | 12:44 PM
Ekizzle's Avatar
Default Re: My dyno (QwkEHtwo)
good HP numbers !
Get a V-AFC and a FPR with a upgraded fuel rail !
Old Jun 7, 2003 | 12:54 PM
Nata$'s Avatar
Default Re: My dyno (AWD 18T)
Do you think my numbers will go up a bit with a FPR and VAFC?
Old Jun 7, 2003 | 01:02 PM
sloppy_seconds's Avatar
Banned
well you might be able to flatten that dip in the middle out...which makes a WORLD of a difference!
Old Jun 7, 2003 | 01:32 PM
TuRbEeZy's Avatar
Damn ur running really lean especially when vtec kiks in, i wouldnt want to be driving like that. Anyway just get a VAFC and get it tuned and yes you will gain a few hp with that and also get rid of that dip b4.Other than that good numbers
Old Jun 7, 2003 | 02:13 PM
chad's Avatar
Moderator
Default Re: My dyno (TuRbEeZy)
what was the correction factor? the torque seems really HIGH!!!! never seen a b16 with mods put down anything close to what you are putting down!
Old Jun 7, 2003 | 02:55 PM
Nata$'s Avatar
I just did two pulls. no tuning. They did not have time for it. I'll go back once I get the FPR and VAFC. Thanks for all of the info. Do you think its safe to drive my car w/ it being lean? I never race and I only use it to drive to work
Old Jun 7, 2003 | 03:30 PM
TurboTeG4's Avatar
Default Re: (QwkEHtwo)
Id just start saving for a turbo kit is all
Old Jun 7, 2003 | 03:37 PM
B16b2b's Avatar
Default Re: (turbocivic4)
good numbers. you must have actually found a strong motor, most of the time that's hard to do
that does seem a little high for i/h/e.......dynoJET?
Old Jun 7, 2003 | 04:53 PM
spencedogg's Avatar
nice vin!!!!!!!!!!!!
Old Jun 7, 2003 | 05:02 PM
FcUK It.'s Avatar
hell yea it would
Old Jun 7, 2003 | 05:27 PM
eg6ajk's Avatar
good torque numbers. overall nice strong motor.
move the vtec to about 5.2k rpm, add some more fuel using FPR or using VAFC or better yet with a mild ECU chip
Old Jun 7, 2003 | 05:46 PM
Nata$'s Avatar
Default Re: My dyno (eg6ajk)
Actually the chip I'm running is a Kenji special. I asked him to make it less aggressive since I don't race and only drive to work *save gas). I also have a P05 ecu that he will chip and make it more aggressive. thanks for the replays Dynojet model 248c got this from Sercet Services website not sure if this is the same one since their site is kinda out dated.
Old Jun 7, 2003 | 05:50 PM
Nata$'s Avatar
Default Re: (spencedogg)
Hi Spence sorry I didn't get to stick around to wait until after you got off work. Hope to see you next time.
Old Jun 7, 2003 | 05:56 PM
Stryker908's Avatar
<---Look you have my logo ! :-D thanks JHP
Edit yours is going the other way haha
matix
Oct 22, 2004 07:26 PM
sagron69
Mar 18, 2004 02:11 AM
VTEC-DA
Mar 24, 2003 04:59 PM
kHoA DoGG
Oct 9, 2002 08:37 AM
StinkyTofu
Feb 25, 2002 02:40 PM
