Lot's of play in clutch pedal.
Old Jul 18, 2001 | 09:00 AM
Steve's Avatar
Default Lot's of play in clutch pedal.
I just noticed today that there seems to be alot of play at the top of my clutch. I can push it about 1.5-2"'s before anything even starts to engage. Is this a sign that my clutch is going, or can this be adjusted?
Old Jul 18, 2001 | 11:42 AM
blkDOHCsol's Avatar
New User
Default Re: Lot's of play in clutch pedal. (Vtec_INSIDE)
thats how my clutch is too...the new si's are even worse. That goddamn thing catches when it is almost out. I dont think that the clutch is going, just thats how it is.
Old Jul 18, 2001 | 11:45 AM
Steve's Avatar
Default Re: Lot's of play in clutch pedal. (blkDOHCsol)
Thanks,
Hey, what are some signs that a clutch is going?
Old Jul 18, 2001 | 11:49 AM
johng's Avatar
There'a a height adjustment, but I don't think it'll cure what you're describing. That's the "free play", and it's normal. Bleed your clutch fluid at the slave cylinder to be sure you have fresh juice. If your clutch disk is gone, it'll be slipping.
Old Jul 19, 2001 | 02:29 AM
DOHC_VTEC786's Avatar
New User
Thanks,
when it starts to slip
Old Jul 23, 2001 | 01:42 PM
Honda4CX-T's Avatar
Default Re: Lot's of play in clutch pedal. (DOHC_VTEC786)
If you step on the Gas and RPM's go up like crazy but you are hardly moving you've got some slipping in the clutch my friend !!!
altoid04
15
Nov 18, 2009 04:10 PM
Dre_559
May 28, 2009 08:23 PM
Kyle244R948
Nov 26, 2008 01:25 AM
Kermit EK
Jan 29, 2003 03:02 PM
