I've searched! Once and for all. can somebody post the correct grounding diagram
I'm going to do the diy version of the hyper ground system. I would really appreciate a clear diagram of the proper grounding points.
Thanx
Thanx
battery to vtec soloniod bolt
battery to alternator bolt (on the mount)
battery to intake manifold bolt (pick one)
battery to distributor bolt
Then not a bad idea to recondition or redo the battery to chassis wire, radiator support to valve cover wire, and chassis to tranny wire.
I would go with one of the 3 distributor bolts.
jaydm ferio
Jan 19, 2005 12:08 PM
