Slightly modded B18C1 dyno also Tach question???
I did 6 runs in total all in 3rd gear. The best out of my first 3 was 155.3hp & 123.1tq with 48psi fuel. They told me I was running way to rich I was @ 12.0 a/f ratio.
My best run was @ stock 40psi 166hp & 129.1tq .
Sorry didn't scan it just took a pic of it. (look @ where it is revving to my gauge cluster shows 8k rpm but the graph shows like 9500 rpm don't know what the **** is wrong with it, lucky I didn't float a valve with my pistons)
Here is my hoop on the dyno.
What do you think can be wrong with cluster being off by so much? It is a stock ex cluster. Should I get a jdm sir cluster? Do you think that will solve the problem?
It sucks cause I have no clue where to **** @ so I shift like @ 7k on my tach all the time now.
I can't wait till get a header (probably the DC JDM 4 to 1) and some CTR or Skunk2 stage 1's with some cams gears tuned. With these additions where do you think I will be @ with my #'s?
Modified by TurboB16Coupe at 12:05 AM 6/7/2003
A header and some cams/cam gears would really make that thing rip, your c/r is there you just need cams to get use out of that high c/r. Cause right now you only making power in the area a stock itr.
car looks clean though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16Coupe »</TD></TR><TR><TD CLASS="quote">What kind of quarter mile times do you think I am @ currently.
Also any clues on the tach issue I am having???</TD></TR></TABLE>
Bump
Bump
Stock tachs are not accurate at all, especially the EX cluster because it has a really low redline compared to the Si/GSR/type R clusters.
