streetable compression
Old Jun 6, 2003 | 06:34 PM
JBk24crx's Avatar
Default streetable compression
is 13.5:1 compression safe to be driven on the street not everyday driving but is it at all streetable.
Old Jun 6, 2003 | 08:47 PM
AussieK24's Avatar
Default Re: streetable compression (rub760)
I'd say it's too high but some people will tell you if it's tuned right you won't have a problem. What motor???
Old Jun 6, 2003 | 09:01 PM
genius's Avatar
i see you are in cali
91 octane and 13.5...negative
12.5 is more like it although i ran 13 to 1 on 92 octane at 13 degrees timing
on hot days it was a bitch and i'd have to retard it some more
Old Jun 6, 2003 | 09:03 PM
JBk24crx's Avatar
Default Re: streetable compression (AussieB20vtec)
h23 vtec
Old Jun 6, 2003 | 09:57 PM
allm0t0rsir's Avatar
tune the car people have done it in cali before
Old Jun 6, 2003 | 10:02 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
12:1 is good enough for me. I drive the car 100 miles round trip a few times a week and it runs great.
Ryan
Old Jun 6, 2003 | 10:08 PM
Westrock2000's Avatar
Default Re: streetable compression (vtecvoodoo)
Through tuning yes you may be able to run 12:1+. However using the stock ECU as many may do, I can say that I think 12:1 is too high even on 93 Octane. My car is driveable, but you cannot push it all the way with out detonation...and thats with the ECU in retard mode, which is heavy fuel and no timing advance. I will probably lower mine to 11.5:1 and see how that goes.
This may be an isolated problem though, as we all assemble our engines differently and there are many different factors involved.
I can say that I have nmot had any overheating problems yet...and its gotten up to about mid 90's so far here in Texas.
Old Jun 7, 2003 | 01:27 AM
Drag R's Avatar
Default Re: streetable compression (omniman)
If your gonna be running 13.5:1 Compression, make sure you're using is in combination with large cams; Toda, Jun, Skunk2, to relieve static compression, which would help reduce the occurance of detonation.
nick
Old Jun 7, 2003 | 02:32 AM
Default Re: streetable compression (Drag R)
Ya in order to lower my compression I'm going to use my 62404's, use a thicker head gasket and open the bowl a little....between all that I should lose hopefully 1/2 point of compression....if more...hey thats fine
Old Jun 7, 2003 | 07:56 AM
JG Luder's Avatar
Default Re: streetable compression (Westrock2000)
I ran in excess of 13:1 for several years on my first H22. Daily.
I never got it to the point where I could run pump gas alone. I always had to run octane booster, or race fuel.
As for power, I think the car spoke for itself. It was a monstor. 240+whp in a "Street car." This was before cams, ECU, and several other things.
Personal opinion? I wouldn't run a stock ECU, and I wouldn't go above about 12:1, and I'd get it tuned right away.
Old Jun 7, 2003 | 10:01 AM
JBk24crx's Avatar
Default Re: streetable compression (Lone Luder)
im going to get it tuned with my hondata s200, and of course im not going to use 91 octane. I just want to drive it from the track back home which is 20 mins away not for freeway driving.
Old Jun 7, 2003 | 10:02 AM
CHRIS 1.8's Avatar
I say anywhere from 11.5 to 12.1 is a good streetable compression.
buffgsr
Jun 6, 2010 12:30 PM
wfocrx
Aug 28, 2006 01:25 PM
cornholioEK
May 21, 2003 07:22 AM
X2BOARD
Jul 10, 2002 12:31 PM
Chuji
Oct 30, 2001 07:26 PM
