Can I fill trans fluid from here?
I don't think so.........99% sure nope...
I once had a Jiffy Lube guy tell me I could fill it through the lil breather tube with the rubber cap on it....(d series tranny) I was like riiiight!!....lol...
Time to put that "beer bong" to a 2nd use!!!
if its a manual tranny, you can use toms trick, just take out the vehicle speed sensor.. romove the one bolt (the long 10mm one-the others hold the vss together) and pull it out.. takes 1.9 qts.
From: Why so you can pretend like youre interested, FL/OK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclidEH3 »</TD></TR><TR><TD CLASS="quote">if its a manual tranny, you can use toms trick, just take out the vehicle speed sensor.. romove the one bolt (the long 10mm one-the others hold the vss together) and pull it out.. takes 1.9 qts.</TD></TR></TABLE>
Here:
https://honda-tech.com/zerothread?id=474557
Here:
Re3irth
12
Sep 1, 2004 02:58 PM
