need help with oil pressure sensor..
i finished installing the turbo except the oil feed and release line.
does anyone know where the oil pressure sensor is on the '00 prelude?
and what's the best way to make the hole in the oil pan, because not many welding shops will weld alumium for me.
thanks!
thanks!
The low oil pressure switch is on the side of the block near the O2 sensor. (Where's your Helm's manual anyway.) I don't know about 5Gs, but the 4G has no oil pressure sensor, only a low oil pressure switch.
If it's a cast aluminum pan it may be a problem unless the guy really know what he's doing. That's why I picked up a steel one.
