Anyone out there running a Cometic HP Headgasket?
Old Jun 5, 2003 | 04:32 PM
FyReo3's Avatar
Default Anyone out there running a Cometic HP Headgasket?
If so, did you notice a sustantial loss of power due to lowering of compression?
Old Jun 5, 2003 | 06:42 PM
EVIL_AWD's Avatar
Default Re: Anyone out there running a Cometic HP Headgasket? (FyReo3)
Cometic makes their headgaskets in different thicknesses. Depending on the thickness you order you can retain or lower your compression. I prefer to run stock thickness on the headgasket and lower the compression with pistons.
Old Jun 5, 2003 | 06:50 PM
TKERacer619's Avatar
Default Re: Anyone out there running a Cometic HP Headgasket? (ITR420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR420 &raquo;</TD></TR><TR><TD CLASS="quote">Cometic makes their headgaskets in different thicknesses. Depending on the thickness you order you can retain or lower your compression. I prefer to run stock thickness on the headgasket and lower the compression with pistons.</TD></TR></TABLE>
Well put. I love my cometic HP gasket. Very high quality.
SCE should have used there copper head gasket for pennies. Worthless Piece of *&%$
Old Jun 5, 2003 | 11:18 PM
earl's Avatar
not the headgaskets fault
b00stedOne
Jul 28, 2014 09:56 AM
High Reved Racing
Jul 14, 2008 04:37 PM
EH-3
Nov 11, 2005 11:28 AM
madman604
Jun 2, 2003 11:09 AM
