Mini-me Timing...Help!
I have the A6/Z6 mini-me in my 89 CRX, I need to know what the secrets to best timing marks others have gone with and had success...it's at 0 right now and my distributor is advanced all the way and it not quick enough and my redline is at 5900...feels like fuel cut-off ot something, it won't go!, and that's with a lot of fuel dumped in (I have an FPR)...can anyone help me out?
-Thanks
-Thanks
ok sooo nobody can help me out? This is all I need to complete the set-up, and I was asking if someone could help me out....come on guys!! I'm in need here!! I just want to know by how much I need to advance/retard the timing to make this setup work well...so how a about it?
I ordered an AEM, but I only think they can be adjusted 3+&3-..can't I do it manually?, like take it off and advance it a couple teeth or whatever...which way does the cam go to be advanced?(clockwise or counter clockwise)
Thanks!
Thanks!
no you can't just take it off and move it cuz the shaft has a small tab that helps lock the sprocket in place when you have it at tdc. if you get the aem you'll need to to turn it towards the + sign to advance. I've been using a JG sprocket on my 89 CRX Si and it has about 10 degrees of adjustment either way
A 5900 rmp redline seems kinda low.. almost as if your vtec is not kicking in. Anyway, I have a y8 mini me set up. I am running 1 step colder plugs and +.5° cam timing advance.. ignition timing is set at at stock. I have no pinging.
considering you are messing with timing and want the most power possible, you should consider getting your car tuned on a dyno.
