smoke i need help!
Old Jun 4, 2003 | 10:19 PM
91sihatchback
Guest
Posts: n/a
Default smoke i need help!
i just bought my 91 si hatch about 3 months ago and its stock and i can rev the car to 7200 before it sputters or whatever....is there something wrong? i smoke white whenever i go from first to second sometimes,but the smoke isnt huge or anything...i changed the oil about a month ago and it quit smoking for 2 weeks then one day i reved hard and it smoked is there something wrong please help!!!!
Old Jun 4, 2003 | 10:27 PM
KooK's Avatar
Mustang Sally
Default Re: smoke i need help! (91sihatchback)
Like I said, you might be getting antifreeze in your cylinders, which means you broke your headgasket, cracked your head or your block, but normall, blown headgasket. If its the stock headgasket, it will happen sooner or later.
your only supposed to rev your engine so high and it will cut out because its hard on it TO KEEP IT UP THAT HIGH!! Floating valves and crap. They're not fun, plus your engine stops making power after so much.
Check your oil, if you have a blown headgasket it should look like this, but white smoke is NOT normal...
Old Jun 5, 2003 | 09:59 AM
91sihatchback
Guest
Posts: n/a
thanks ill check it out does anyone have any other opinions
Old Jun 5, 2003 | 01:22 PM
91sihatchback
Guest
Posts: n/a
bump...
Old Jun 5, 2003 | 01:29 PM
91sihatchback
Guest
Posts: n/a
my oil doesnt look like that its still dark colored and my engine and my head arent cracked!!!!?? whats the deal then is it still just a bad head gasket?
Old Jun 17, 2003 | 10:57 PM
Turbo'dMex-A-Keen's Avatar
Default Re: (91sihatchback)
Get a new MOTOR, ENGINE, THING THAT MAKES YOUR CAR PROPEL, HEAD, BLOCK, or maybe even the DOHC OUT OF YOUR INTEGRA!.......................................... .................................................. .................................................. .................................................. ...............................
Old Jun 18, 2003 | 09:17 AM
rflum's Avatar
I had a '90 hatch that was losing about a quart of water every 50 miles (mostly highway, 70 mph). It was smoking blue-white cuz it was burning oil and water. Lost a quart of oil every 200 miles. Oil looked fine, not milky. I put in 1/2 a can of Blue Devil sealer and idled for 40 minutes, then drove it 1200 miles to Alabama the next day. It never needed another drop of water, and it smoked less, although it still burned oil about the same rate. Could have been a small gasket leak or a hairline crack in the head (only would show up if Magnafluxed). Rob
Old Jun 18, 2003 | 03:23 PM
MaaseyRacer's Avatar
Default Re: (rflum)
i had a similar problem with my 89 civic dx, but i was smoking when i down shifted from 4 to third when exiting a freeway or something, it turned out to be my valve stem seals, it took me half a day to figure out how to replace them and do it, and i have not smoked since...
Bigbassbillie
May 4, 2016 08:34 PM
itr590
Nov 30, 2007 12:41 PM
philkehn
29
Aug 31, 2006 11:16 AM
froggie3kb
19
Oct 30, 2003 06:15 PM
LSyellowREX
Aug 1, 2002 11:37 AM
