SOHC Vtec lope question??
Old Jun 4, 2003 | 08:11 PM
Timmah!!'s Avatar
Default SOHC Vtec lope question??
I want to test my Vtec solinoid, and I want to know if I hook a +12v to the solinoid at idle with a D15b if I would hear it lope? I can here the solinod click, but I dont know if it is switching profiles. Thanks
Old Jun 5, 2003 | 06:47 AM
Timmah!!'s Avatar
Default Re: SOHC Vtec lope question?? (azroth)
Or is there any other way to test the solinoid while it is on the car?
Old Jun 5, 2003 | 06:59 AM
Mr Furball's Avatar
If you hear it clicking then it's good.
Old Jun 5, 2003 | 08:18 AM
Timmah!!'s Avatar
Default Re: SOHC Vtec lope question?? (FURBALL B-16)
Even though I dont hear the motor lope at idle after applying +12v
Old Jun 5, 2003 | 07:04 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth &raquo;</TD></TR><TR><TD CLASS="quote">Even though I dont hear the motor lope at idle after applying +12v</TD></TR></TABLE>
i don't think it will lope, because there's not enough oil pressure for the vtec lobe to come into play. my .02c
Old Jun 5, 2003 | 07:13 PM
Timmah!!'s Avatar
Default Re: SOHC Vtec lope question?? (smokey2.0)
So even if you jump the solinoid it wont switch profiles at a low RPM?
Old Jun 5, 2003 | 07:43 PM
smokey2.0's Avatar
right! try it while the car is running(on the road)! good luck!
Old Jun 6, 2003 | 05:22 PM
The Rob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth &raquo;</TD></TR><TR><TD CLASS="quote">So even if you jump the solinoid it wont switch profiles at a low RPM?</TD></TR></TABLE>
Thats correct. VTEC uses engine oil pressure to engage, so if you lack enough oil pressure then you have no VTEC.
Old Jun 6, 2003 | 07:04 PM
smokey2.0's Avatar
Default Re: SOHC Vtec lope question?? ( Rob)
any progress dude, check the screen behind the vtec/oil switch. if that screen is clogged, you'll have no oil pressure to activate vtec!
Old Jun 7, 2003 | 04:57 AM
durangedesign.com's Avatar
Take the lead coming off your Silinoid and hook it directly up to your possitive terminal, if it clicks you know it works. Now make sure you CTS is working because Vtec will not work if the engine is not warm, at least mine wouldn't.
Old Jun 7, 2003 | 05:41 AM
smokey2.0's Avatar
Default Re: SOHC Vtec lope question?? (durangedesign.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by durangedesign.com &raquo;</TD></TR><TR><TD CLASS="quote">Take the lead coming off your Silinoid and hook it directly up to your possitive terminal, if it clicks you know it works. Now make sure you CTS is working because Vtec will not work if the engine is not warm, at least mine wouldn't.</TD></TR></TABLE>
what's the CTS?
Old Jun 7, 2003 | 05:59 AM
coolant temp sensor
Old Jun 7, 2003 | 07:04 AM
Timmah!!'s Avatar
Remember everyone, I am forcing the solinoid with and activated switch, it is NOT controlled by the ECU.
junk95civ
25
Jan 29, 2010 12:09 PM
DougNuts
Dec 30, 2007 04:48 PM
traxxasx
Oct 19, 2007 01:58 PM
lmiguelvv
25
Sep 25, 2004 03:45 PM
Red_Si
12
Feb 16, 2003 04:17 PM
