H22 tranny versus F22 and H23 tranny. Who wins?
Old Jun 4, 2003 | 06:54 PM
dominate9's Avatar
Default H22 tranny versus F22 and H23 tranny. Who wins?
On a turbo H22 engine, on which tranny would the quickest quarter mile time be achieved? The H22 tranny, H23 tranny, or F22 tranny.
Old Jun 4, 2003 | 06:56 PM
dominate9's Avatar
Default Re: H22 tranny versus F22 and H23 tranny. Who wins? (dominate9)
I think the F22 tranny would get the quickest time because of the longer 2nd, 3rd, and 4th gear. I am about to boost my H22 and I want to have the tranny that will give me the quickest time.
Old Jun 4, 2003 | 09:37 PM
safe driver's Avatar
it's quite simple really.
h22a tranny is faster in stock form, thus
h22a tranny will be faster in FI form.
Old Jun 5, 2003 | 12:33 AM
kotetu's Avatar
Default Re: (safe driver)
Shorter gearing is better for faster acceleration.
I am not exacly sure why longer gearing is better for Turbo aps, (so I have heard), maybe it is because the longer gears help the turbo to spool up?
Old Jun 5, 2003 | 05:22 AM
dominate9's Avatar
Default Re: (kotetu)
Between shifts, the turbo spools down and you lose boost. WHen you have longer gears, you don't have to shift as much and therefore you get to keep more boost going. That is why longer gears and turbo mix. And that is why I think the H23 and F22 would be better for a turbo H22. The F22 might be the best.
Old Jun 5, 2003 | 05:23 AM
dominate9's Avatar
Default Re: (dominate9)
Anyone out there with some experience? I'm looking for more fact than opinion.
Old Jun 5, 2003 | 05:27 AM
bgod's Avatar
h22a tranny by far. used to run an h22a in my accord with a custom set-up. also had a 2.0l integra with haltech and itr tranny with kaaz lsd.
post this question in the fi board. acceleration wise the shortest gearing will get you there. not n/a drastic short but h22a and itr tranny's gearing is plenty. even on 500whp cars.
using a long geared tranny is a total myth. longer gears do provide for some comfortable daily drivers but when acceleration is involved only shorter gearing wins out.
Old Jun 5, 2003 | 05:34 AM
dominate9's Avatar
Default Re: (bgod)
I found some evidence that longer gears are better.
http://www3.telus.net/public/bunryn/tranny.html
Old Jun 5, 2003 | 07:40 AM
d98clturbo's Avatar
i am using the f23 tranny with my turboed h22 in my acura cl.....it is alot faster than the h22tranny...i have had both and much rather the f23 tranny....my boy had the same setup except he had the h22 tranny while i had the f23 tranny we raced and i just walked on him...remember they say you lose 1/10th of a second on every shift (if you are a good driver, maybe more) so with the shorter gears you will have to shoift more often which can result in a using more time
just my $0.02
Old Jun 5, 2003 | 07:57 AM
bgod's Avatar
Default Re: (d98clturbo)
your link proves nothing. the fact is the shorter the gearing the better for accerleration. i'm not talking 4.7fd, but 4.4fd and below isn't bad.
i guess you just have to have the set-up to know. the only benefit of holding out each gear with a longer geared tranny is comfort. if you can drive your car and shift properly you will accelerate quicker, it's as simple as that.
i was pushing 345whp on my integra at 12psi. with a whopping 330whp at 5500rpm. trust me, my 4.4fd itr tranny allowed me to get to 130mph in no time.
Old Jun 5, 2003 | 08:25 AM
PreludeRacer023's Avatar
the H22 tranny will be the fastest, you wont have any trouble between shift spooling the turbo, they rev to almost 7800 rpms....when you shift you fall to around 5700 or higher if u go to 8k...those rev speeds will keep the turbo spooling...and if you can shift properly the turbo wont lose that much anyways, if you suck at shifting youve got a problem, which is why so many "kids" with these turbo cars suck at driving them....the longer gears may be a slight advanyage on the freeway like from an 80 mph roll race or for top end but for 1/4 mile acceleration, the shorter tranny is better
Old Jun 5, 2003 | 08:28 AM
DLB1994's Avatar
Default Re: H22 tranny versus F22 and H23 tranny. Who wins? (PreludeRacer023)
thats why i run a h22 tranny on my h23
Old Jun 6, 2003 | 12:57 PM
dominate9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d98clturbo &raquo;</TD></TR><TR><TD CLASS="quote">i am using the f23 tranny with my turboed h22 in my acura cl.....it is alot faster than the h22tranny...i have had both and much rather the f23 tranny....my boy had the same setup except he had the h22 tranny while i had the f23 tranny we raced and i just walked on him...remember they say you lose 1/10th of a second on every shift (if you are a good driver, maybe more) so with the shorter gears you will have to shoift more often which can result in a using more time
just my $0.02</TD></TR></TABLE>
What are the gear ratios for the F23 tranny that you're using? You don't mean F22, do you?
Old Jun 6, 2003 | 01:01 PM
h22 civic's Avatar
h22 dont ya want the motor to rev quicker
Old Jun 6, 2003 | 09:58 PM
d98clturbo's Avatar
Default Re: (h22 civic)
iam not sure what the gear ratio is in the f23 tranny....the f22 /23 tranny are the same....
Old Jun 6, 2003 | 10:18 PM
KW2000's Avatar
F22a1 tranny drops outa vtec in 2nd becuz of the long 2nd gear... a h23a1 will take the f22a1 tranny..becuz..well...ive seen the battle before and the h23a1 won..a couple of times...the mods where about the same on both cars
Old Jun 7, 2003 | 07:46 AM
d98clturbo's Avatar
when i wa N/A i never fell out of vtec in any gear..i used to shift my car at 8000 rpms..when i pulled 2nd the rpm's droped to around 5700 rpms
Old Jun 7, 2003 | 10:40 AM
forcefed's Avatar
no one mentions traction in this subject ever, i have found it very benifical to use the f23 over the h22 due to the fact that the longer gears keep me from burning out as long my best time with the h22 tranny was a very inconsistant time of 12.821 being the best. with the f23 tranny i am much, much more constitant and my best being a 12.614 and this is on street tires, maybe the h22 would be better with slicks i could see that, but i would not trade mine for the h22 ( i already have one)
Old Jun 7, 2003 | 10:50 AM
Elkins911's Avatar
Default Re: (forcefed)
i always thought you couldnt mix and match different motor series parts. ie: h with f.... or b with d series.
Old Jun 7, 2003 | 10:59 AM
dominate9's Avatar
Default Re: (KW93LUDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KW93LUDE &raquo;</TD></TR><TR><TD CLASS="quote">F22a1 tranny drops outa vtec in 2nd becuz of the long 2nd gear... a h23a1 will take the f22a1 tranny..becuz..well...ive seen the battle before and the h23a1 won..a couple of times...the mods where about the same on both cars</TD></TR></TABLE>
I assume that both the cars were boosted because that is that this post is talking about. Read up. We aren't talking about N/A applications. We're talking about boost.
Old Jun 7, 2003 | 11:10 AM
Boostless97Lude
Guest
Posts: n/a
you can find your answer here https://honda-tech.com/zerothread?id=421083
rico892002
Aug 18, 2009 04:01 PM
1slwcoupe
Jan 17, 2007 05:57 PM
o2 jockey
Feb 16, 2004 06:23 AM
rocket_R
Feb 20, 2003 05:52 PM
b18bEG
Sep 15, 2002 11:19 AM
