Radio and tach dying!!!
Old Jun 4, 2003 | 05:27 PM
90da's Avatar
Default Battery, radio and tach dying!!! Help please
Ok, I have a really weird problem. This morning when I got to work my stereo and my stock tach(aftermarket one was fine) died. The clock on the radio was still working so I know it was getting power. It is a small clock btw off to the side of the deck. Well anyways, I popped the hood and took a look and everything seemed fine so I shut the car off and it wouldn't restart. After I jumped it and moved it, it wouldn't start again. anyways I charged the battery and put it in and tested it and the car started. Now I'm back to the same point, but the alt is almost new. I just want to know why would the radio and stock tach not work if it is just the alt. dying ? TIA....I really need my car fixed so I need ideas to try out 2morrow morning at work.
Old Jun 4, 2003 | 06:11 PM
90da's Avatar
Default Re: Battery, radio and tach dying!!! Help please (90ef)
BuMp.....I need some ideas so I can figure it out tomorrow. PLEASE!!!
Old Jun 4, 2003 | 06:15 PM
91civicEX's Avatar
check all your fuses.
Old Jun 4, 2003 | 06:24 PM
Nature's Renewal's Avatar
especially the fuses to your electric charging system
Old Jun 4, 2003 | 06:25 PM
MAD SCIENTIST's Avatar
Default Re: (91civicLX)
alt is dead.do u have a voltmeter?if not just replace the alt
Old Jun 5, 2003 | 08:01 AM
90da's Avatar
This morning I found the green plug connected to the alt feels really loose. But it still doesn't explain the link between the radio and the tach, and why doesn't my aftermarket tach die as well? I'll have to look at lunch.
Old Jun 5, 2003 | 06:22 PM
Default Re: (90ef)
when u loose your alt the car kills all the stock power options.its kinda like a safe mode.aftermarket things wont be affected because there not run like stock.
Old Jun 6, 2003 | 01:08 PM
90da's Avatar
Thanks....I found the problem btw, it was the green plug in the alternator. The clip somehow broke off of it and the plug was coming loose. I have it ghetto rigged now, Blue thread lock and a little super glue for now until I can get a new plug.
KyleVA
Jun 24, 2011 03:55 PM
FistertonDeLuxe
Nov 30, 2006 07:55 AM
chu77
Sep 16, 2006 12:57 PM
kkw103
Oct 4, 2005 09:29 AM
dcfour
May 12, 2005 09:34 PM
