Broke a valve cover stud! What to do?
Old Jun 4, 2003 | 04:26 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Broke a valve cover stud! What to do?
Went out to change the plugs today. After taking off the little grey plug cover I noticed the nuts the hold the little grommets on the valve cover had worked themselves back up (happens almost every time I assume from loosening the nuts on the plastic cover). Anyways when I went to snug it back down one broke off and I don't have enough thread left to put the nut back on. Don't tell me I'm going to have to get the stud replaced . Is it possible for me to just be some gasket seal all around the grommet or is it that important.
Nothing is ever easy.
< is frustrated right now.
Old Jun 4, 2003 | 04:30 PM
P1mpSlap's Avatar
ok, it's One of the Four studs that hold the spark plug cover on right?
If so, You can just remove the valve cover and then use a 12mm deep well to remove the stud. No need to tap it out or stuff like that.
You might as well replace ALL of them while you are doing it. I had to do this on a friends car and after I replaced one, another broke. So just replace all 4. Common problem. Nothing to worry about tho.
all stock's Avatar
Default Re: Broke a valve cover stud! What to do? (ActiveAero)
few people on this board have been running without a few of them for a lil while.
ask emerika. i think he's been running w/o like, 3. lol
Old Jun 4, 2003 | 04:31 PM
jdmspoonitr's Avatar
You are not the only one. I broke off the stock strut bar stud a long time ago and the dealer told me I would have to drill it out and weld a new one, so I said fugg it.
BlueR's Avatar
just get a new stud...they are cheap and relatively easy to replace
i broke one of mine b4 and it took 5 minutes to replace
SurferX's Avatar
The studs are only a couple bucks, and screw right in easy. Not a big deal to replace it. Yes I hate those studs as well, I torque mine to perfect 7.2 lbs-ft each time in the right order and sometimes I still get one stripping from time to time. Thankfully though Honda made it very easy and convenient to replace the studs.
Old Jun 4, 2003 | 04:32 PM
[HrZn]4life's Avatar
Default Re: Broke a valve cover stud! What to do? (all stock)
haha..yeah, I ran without one of my valve cover stud/nut for about 2 years. Just replaced it recently. It's easy. Just take off the valve cover and replace the stud.
Old Jun 4, 2003 | 04:40 PM
boszyen's Avatar
That happened to me about a month ago...
I couldn't get the stud out, so I had to take it to Honda
They charged me $70 for that.
Without the stud and the rubber seal (ring), oil burst everywhere, and on idle, air is coming out of it.
Does this happen to anyone else?
Old Jun 4, 2003 | 04:56 PM
acuracing's Avatar
Default Re: Broke a valve cover stud! What to do? (boszyen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boszyen &raquo;</TD></TR><TR><TD CLASS="quote">That happened to me about a month ago...
Ouch.
Old Jun 4, 2003 | 05:01 PM
SoCal ITR's Avatar
Default Re: Broke a valve cover stud! What to do? (acuracing)
It's happened before, I don't even keep that little grey valve cover on anymore.
Old Jun 4, 2003 | 08:11 PM
SergEK's Avatar
Default Re: Broke a valve cover stud! What to do? (SoCal ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal ITR &raquo;</TD></TR><TR><TD CLASS="quote">It's happened before, I don't even keep that little grey valve cover on anymore.</TD></TR></TABLE>
Same here.....my dist side valvecover stud spins in place
I keep the wireplug cover off to save the hassle
Old Jun 4, 2003 | 08:29 PM
Rory Breaker's Avatar
Default Re: Broke a valve cover stud! What to do? (SergEK)
Been running minus 2 forever now...at least a year. No problems here...cake replacement as well. Take off valve cover unscrew stud and screw new one in.
Old Jun 4, 2003 | 09:09 PM
Rdriven's Avatar
Default Re: Broke a valve cover stud! What to do? (newgsrdriver)
Yeah I did that a couple weeks ago. The studs around the spark plug cover are Honda part # 90014-PR3-000 and the gold nut that holds the grommet/valve cover is 90212-PR3-000
Old Jun 4, 2003 | 09:30 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Thank goodness! I thought for sure I was going to have to get it tapped out by a machine shop or something. Looks like I'll cake it with a touch of gasket seal until I replace it and go ahead and do them all while I'm at it. Thanks for the info.
Honda-Tech has relieved stress once again.
Old Jun 7, 2003 | 02:31 PM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
i think i overtightened ( which i doubt ) the lower right hand nut on the valve cover. Any idea's on how to get that one off? I think the thread might have been crossed. During my car's downtime i wanted to check it out and remove the valve cover but that nut just sits there and turns. it won't come off. Any idea's on that ?
SteezyEG
12
Oct 28, 2012 02:23 PM
standbackimapro
Dec 16, 2005 11:07 AM
wowowee
24
Jul 19, 2005 05:04 PM
99teggsr
Apr 17, 2005 09:54 AM
kreamy
Oct 2, 2003 06:43 AM
