Test Pipe VS. High Flow CAT
Old Jun 4, 2003 | 03:14 PM
H23A1LUDE's Avatar
Default Test Pipe VS. High Flow CAT
I'm getting a test pipe along with the custom 2.5" mandrel bent piping from kteller8 and I'm wondering if it provides much more hp and flow than a high flow CAT. I live in FL so I don't have to worry about emissions. I'm worried that if I get the test pipe, that in the future when I decide I want to sell my lude, I won't be able to due to the illegal test pipe. With exhaust it's all about better flow and the test pipe would definately provide that....but how much better than a high flow CAT? thanks
Old Jun 4, 2003 | 03:36 PM
roadawg's Avatar
Default Re: Test Pipe VS. High Flow CAT (H23A1LUDE)
The test pipe will definitely flow more air than a high flow cat. If emissions aren't an issue in your area i say go with a test pipe.
Old Jun 4, 2003 | 05:09 PM
redemptionracing's Avatar
I was talking to the owner of a local exhaust shop. He said that a High Flow cat was just the legal way of having test pipe performance. He said it would make no difference.
Old Jun 4, 2003 | 08:26 PM
bullet9925's Avatar
New User
Default Re: (redemptionracing)
how the heck will you stop the engine light from staying on from the O2 sensor?
Old Jun 4, 2003 | 08:36 PM
sslude's Avatar
Default Re: (bullet9925)
o2 sensor simulator
Old Jun 4, 2003 | 08:43 PM
Cottonwoodz's Avatar
OBD1...
Old Jun 4, 2003 | 08:49 PM
H23A1LUDE's Avatar
Default Re: (Cottonwoodz)
****...will I really have to put out more money to keep the engine light from coming on...that sucks. I don't know if I want to test pipe now....just to keep from the hassle of f*ckin with the o2 sensor. Is it hard or easy?
Old Jun 4, 2003 | 08:52 PM
Default Re: (H23A1LUDE)
No, you have a 4th gen correct?
Old Jun 4, 2003 | 08:53 PM
H23A1LUDE's Avatar
Correct, 4th gen H23
Old Jun 4, 2003 | 10:23 PM
domslude's Avatar
if i'm correct the o2 senser is in the header, not the cat.
Old Jun 5, 2003 | 06:04 AM
Merritt_si's Avatar
as long as you don't have a 96 then you have OBD1 and you are good. If you do have a 96 then all you need is a OBD2 to OBD1 conversion harness. Or I thought there was a how to either here or on Superhonda.com.
Peace
Old Jun 5, 2003 | 06:34 AM
munscher's Avatar
Default Re: (Merritt_si)
what kind of nominal hp differences are we talking between a test pipe and hi-flow cat? assuming appropriate airflow is supplied (CAI, header, exhaust have all been added)
Old Jun 5, 2003 | 07:14 AM
H23A1LUDE's Avatar
Default Re: (munscher)
That's good to hear. I already ordered my setup from Kteller and just have to send him the money.
Old Jun 5, 2003 | 07:16 AM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Merritt_si &raquo;</TD></TR><TR><TD CLASS="quote">If you do have a 96 then all you need is a OBD2 to OBD1 conversion harness. </TD></TR></TABLE>
Well, you would also need an OBDI ecu to go with the conversion harness If you have OBDII and want to run a test pipe CEL free, just do the OBDII "workaround": http://www.ntpog.org/mods/fifth-afc/ecu.shtml
Old Jun 5, 2003 | 07:58 AM
osuPrelude's Avatar
Default Re: (sharkcohen)
So to propagate my laziness , does someone know how much would a full OBDII to OBDI system would cost? It seems to be a good investment. Thanks
Old Jun 5, 2003 | 08:00 AM
lildrgn2.0's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">
Well, you would also need an OBDI ecu to go with the conversion harness If you have OBDII and want to run a test pipe CEL free, just do the OBDII "workaround": http://www.ntpog.org/mods/fifth-afc/ecu.shtml</TD></TR></TABLE>
doesnt work forever..
the work around works for about 8 months... then the CEL appears in full force and you can not reset to get rid of it..
Old Jun 5, 2003 | 08:17 AM
sharkcohen's Avatar
Default Re: (Lildrgn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lildrgn &raquo;</TD></TR><TR><TD CLASS="quote">
the work around works for about 8 months... then the CEL appears in full force and you can not reset to get rid of it.. </TD></TR></TABLE>
Woah, that is the first I've heard that
Modified by sharkcohen at 6:09 PM 6/5/2003
401tuner
Jun 3, 2007 04:03 PM
808State
May 14, 2002 11:12 AM
integraty
Apr 17, 2002 07:54 PM
Blue-Civic-Hybrid
12
Apr 11, 2002 04:39 PM
JDM_Type-R
Jan 2, 2002 04:07 PM
