check engine light just wont go away
Old Jun 4, 2003 | 11:52 AM
respectblades's Avatar
Default check engine light just wont go away
ok i have a 94 hb with a b16a 2nd gen
i have cleared all check engines codes except the intake air temp sensor...
i have absolutely no idea why this sensor just wont work ...
its brand new ..
i have a rechipped computer from low cash racing...
i don'tknow if its possible that anything in the ecm is causing the problem
Old Jun 4, 2003 | 11:55 AM
RSZero1's Avatar
Default Re: check engine light just wont go away (respectblades)
check if it's in all the way, if it's clean and unplug it then plug it back in to make sure the connection is tight.
Old Jun 4, 2003 | 11:59 AM
Default Re: check engine light just wont go away (RSZero1)
ya i jsut did that a few minutes ago ..
right now i'm waiting about half an hour to reconnect my battery and my ecu fuse...
praying for a miracle...
Old Jun 4, 2003 | 12:07 PM
acuracing's Avatar
Check all wires and if necessary trace them from the sensor all the way to the ECU. A voltmeter would work too to see if you're getting correct signal.
anduhy
Jan 16, 2008 11:17 AM
brentaction22
May 24, 2007 09:28 PM
respectblades
Jun 4, 2003 04:18 PM
JustinL
18
Mar 28, 2003 05:05 AM
