Check Engine Light from intake
Old 03-25-2003, 06:43 AM
JustinL's Avatar
Default Check Engine Light from intake
I put a cai on my car and my check engine light came on. i went to autozone(i know, they dont know **** about my car) and had them run their free diagnostic. the guy said the ecu was massing up because of the extra air going into the motor. i tried resetting the ecu, but to no avail. Did the stock airbox have more than one plug going into it? if so that might be my problem....
Old 03-25-2003, 06:47 AM
IS3Fifty's Avatar
Default Re: Check Engine Light from intake (pyro_assassin)
o2 sensor
Old 03-25-2003, 07:16 AM
andrew dc's Avatar
pull you negative battery cable, or both of them for a minute or so, and then put them back on... it should reset everything.
Old 03-25-2003, 08:32 AM
silver99's Avatar
Default Re: Check Engine Light from intake (CRX25)
what year is your car? I have two on my 99 and they both need to be reading something off the CAI. When I did some work on my car I let one sensor hanging out and some smoke was blowing off the header and caused a CEL. Unhooked the bat, put the sensor in and everythign was fine.
Old 03-25-2003, 08:43 AM
SOHC_MShue's Avatar
he said he already tried that.
Old 03-25-2003, 08:57 AM
B16A2-EM1's Avatar
Default Re: Check Engine Light from intake (SOHC_MShue)
You need to reset your ECU, take it to Honda dealership they do it for $20 bux. Or DIY.
[Modified by B16A2-EM1, 9:58 AM 3/25/2003]
Old 03-25-2003, 11:24 AM
vladd's Avatar
Default Re: Check Engine Light from intake (B16A2-EM1)
Old 03-25-2003, 11:56 AM
bjaeyang's Avatar
Default Re: Check Engine Light from intake (civicdxtyper)
did you forget to put your air filter sensor back into your cai.
Old 03-25-2003, 12:34 PM
BLUTO's Avatar
When I put my CAI in my civic, my engine light cam on too. I waited about a week and I guess it reset itself b/c the light was off one morning. You might want to try waiting if nothing else seems to be working.
Old 03-25-2003, 12:38 PM
MLogan's Avatar
The dealership charges $20 to reset ECU? Do they jsut unplug the battery for you?
Old 03-25-2003, 02:44 PM
DarkCyde SI's Avatar
Default Re: Check Engine Light from intake (MLogan)
do only obd II cars have o2 sensors in the intake? i don't recall having one in my car. it's OBD I
Old 03-25-2003, 03:00 PM
FabulousSi
Guest
Posts: n/a
Default Re: Check Engine Light from intake (civicjdmgsr)
I say its the secondary o2 sensor, that was my prob.
Old 03-26-2003, 09:34 AM
vladd's Avatar
Default Re: Check Engine Light from intake (BLACK99civicEX)
same thing happened to my friend's 96 ls. the cel came on after putting on a short ram, and just went away after about a week.
Old 03-26-2003, 11:43 AM
LSVtecEK1's Avatar
they just hook up some machine under the dash and it gives a signal as to why the check engine light is on, then they reset it, but i got mine done for free when my speed sensor was broken.
Old 03-26-2003, 11:44 AM
JustinL's Avatar
i have a plug hanging but theres only one input area for the two. damn ebay intake for $50!!
Old 03-27-2003, 06:55 AM
PupaScoopa's Avatar
Intake temperature sensor anyone? I forgot to plug mine back in after a CAI install and got the CEL.
Old 03-27-2003, 09:21 AM
clutch33's Avatar
Try disconnecting the negative battery terminal for a minute or so. I know with mine, that worked. I have also heard that after a certain number of starts, it will reset but I don't know about that. Good luck
Old 03-27-2003, 09:26 AM
nerces's Avatar
thats about all they do lol
Old 03-28-2003, 05:05 AM
silver99's Avatar
Default Re: Check Engine Light from intake (nerces)
Just drill another hold in you intake and put it in there, then you should be all set. Otherwise, see if you can get some sort of split adapter so that you can fit both into the one hole.
pinky5
09-01-2008 02:29 PM
turcasso
01-05-2008 02:52 PM
Car Tweaker
05-06-2007 12:25 PM
PhatwhipsJDMkits
11-28-2004 09:31 AM
mnbv
07-09-2004 10:50 AM
Quick Reply: Check Engine Light from intake
