Door Panel
Hey guys, i just created this name...but anyways, My sisters window is off its track. She has a 93 4 door, with power windows. The window im tryin to fix is the rear passanger side. i was able to get the bottom and the sides of the panel un-hooked, but i cant get the top to budge. thanks for the help guys
u should've poped out 2 plastic screws
1 in top somewhere one at bottom somewhere
then, like he said theres 1 where the armrest is
u pop out the plastic cover and undo the screw
then, where the handle it there might be 1 more i'm not 2 sure about that but if theres a little cover then theres a screw u have to undo there, after u undo that screw u have to pop out the door handle itself....
just try pulling on it from either side till it comes out
disconnect the power to the door handle and also remove the window controller from the armrest or wherever it is and disconnect the power ot that 2
after u get the door handle right out u can remove the entire panel
its clipped in so u have to give it a good pull and it'll pop right out
casper.hughes
Oct 12, 2008 06:33 PM
fasterthanrayswrx
Jan 26, 2007 04:36 PM
serious
Sep 6, 2002 04:40 PM
