weird whistle noise
Old Jun 3, 2003 | 10:16 PM
krnboixshawn's Avatar
Default weird whistle noise
i have a 5th gen prelude and i just installed the headers and a sound system. well when i step on the accerator i hear this whistle noise as the rpm goes up. i popped open the hood to hear if its coming from the header but i dont hear anything, only inside my car. so i was thinking if it could be from the hole that the tech had to drill from my engine bay to the cockpit for my system when running wires. any ideas? also if it is the header, whats wrong with it
Old Jun 4, 2003 | 05:23 AM
CHK4TIX's Avatar
Default Re: weird whistle noise (krnboixshawn)
its probably alternator noise threw your new system
Old Jun 4, 2003 | 05:44 AM
Sephro's Avatar
Default Re: weird whistle noise (CHK4TIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX &raquo;</TD></TR><TR><TD CLASS="quote">its probably alternator noise threw your new system</TD></TR></TABLE>
you need to check your ground first off if that's okay then you need to get noise filter. Like this http://www.crutchfield.com/S-f...ANS80
Old Jun 4, 2003 | 06:11 AM
kay_animation's Avatar
Default Re: weird whistle noise (Sephro)
I want my car to make a weird whistling noise... Followed by a Tsssssssssss... But thats just turbo dreams.
Old Jun 4, 2003 | 06:13 AM
munscher's Avatar
yup, i'd guess alternator whine as well.... i've always heard that installing a cap should fix that
Old Jun 5, 2003 | 07:00 AM
preluder's Avatar
Default Re: weird whistle noise (munscher)
i dont know but everytime i hear mine i love it wont change it for the world.
Old Jun 5, 2003 | 07:33 AM
del_parker's Avatar
nope, caps don't fix it, because mine could still be heard when i turned the stereo off. remote turnon was wired to the acc.
Old Jun 5, 2003 | 08:59 AM
PetroGuyX's Avatar
run your power wire on the opposite side of RCA's, that's what causes road noises, it'll fix everything, i promise
Old Jun 5, 2003 | 10:36 AM
munscher's Avatar
Default Re: (PetroGuyX)
yeah, i ran power up the passenger side, and RCAs up the center of the car... i have no problems whatsoever
Old Jun 5, 2003 | 11:29 AM
SsTiNgEr77's Avatar
I have a whistle noise when i have my headlights on with my system, i turn off the lights it goes away, turn off the system with the lights on it goes away... whats best way to go at that?
Old Jun 6, 2003 | 08:07 AM
Sephro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX &raquo;</TD></TR><TR><TD CLASS="quote">run your power wire on the opposite side of RCA's, that's what causes road noises, it'll fix everything, i promise</TD></TR></TABLE>
Yes if you do run speaker wire along side power wires the EM is picked up causing noise. If possible I would say wire your ac wire to the radios AC wire so the amp won't be on. Also Check your ground wires. Is the ground wire tight to the cars body? Is it metal on metal with no paint? Do you have a large enough Gage wire for the ground? Ground problems can cause all kinds of difficult to pin point noises.
Old Jun 6, 2003 | 12:04 PM
tha Big EZ's Avatar
the only person in here with the turth!^
Metalmat
Feb 8, 2022 02:54 AM
TurdBlown Teg
Aug 2, 2006 06:53 AM
honda95civic
Audio / Security / Video
12
Jun 21, 2006 11:03 AM
devilpuppy
22
Jul 22, 2004 06:34 AM
Unjockable
May 31, 2002 11:08 PM
