Fidanza flywheel problems...
Old Jun 3, 2003 | 09:37 PM
skrewdlude's Avatar
Default Fidanza flywheel problems...
Ok,
I have had this flywheel for almost 2 years now, and no problems. Lately though when I try to start the car it sounds like the starter teeth are grinding against the flywheel. It makes this really loud, grinding noise, and never turns over. The weird thing is that if I take the key completely out of the ignition, and re insert it. It will usually start right up. Sometimes tho it won't and takes a couple tries. It use to do it every now and then, but not nearly as much as it does now. When I had the motor out of the car I checked the flywheels teeth, and there were a couple marks, but nothing serious, and they were barley noticeable.
Has anyone experienced this problem? It is really getting on my nerves
Thanks,
Josh
Old Jun 3, 2003 | 09:40 PM
NXLude's Avatar
How old is your starter? It might just be going bad.....
Old Jun 3, 2003 | 09:56 PM
skrewdlude's Avatar
Default Re: (NXLude)
It came with the JDM motor i think. I guess I will try swapping on my new starter. Is that what happens when a starter goes bad?
Thanks,
Josh
Old Jun 4, 2003 | 12:30 AM
piotrush's Avatar
Default Re: (skrewdlude)
I heard a few people complaining that JDM flywheels like JUN were not compatible with USDM starters because they were different. The result would be occasional grinding. If this is true maybe your JDM starter is not compatible with a USDM flywheel. Can anyone confirm this?
Old Jun 4, 2003 | 05:52 AM
Anubyss's Avatar
Default Re: (piotrush)
The issue is the ring gear not aligning properly with the starter. I've had this issue from the beginning. I didn't get it all the time but about 20% of the time. Fidanza told me they changed the ring gear about six months ago so I sent mine back to have everything replaced for $125. Don't know if I'll put it back in though. I've even seen the same issue with Jun flywheels. Strange thing is, I know some people with Fidanza that does not have this issue. I know Fidanza started installing bearings in the center about two years ago but don't know if changing the ring gear is bs or not. Someone call them and see what you are told.
Old Jun 4, 2003 | 07:20 AM
bgod's Avatar
Default Re: (Anubyss)
had the same problem right from the beginning with my old cm flywheel which is made by fidanza.
Old Jun 4, 2003 | 04:29 PM
alphajesse's Avatar
The ring gears on those are OEM- I can't see how an OEM part would be a problem...
Old Jun 4, 2003 | 05:12 PM
redemptionracing's Avatar
Maybe the starter bolts came loose? Happened to a friend once.
TylerC161
Dec 29, 2007 11:21 PM
Andyb22g
Nov 22, 2004 03:30 PM
leboeuf45
May 13, 2004 07:48 AM
92lsr
Jan 17, 2004 09:27 AM
accordfreak
Oct 29, 2003 03:00 PM
