LS questions
Old Jun 3, 2003 | 05:55 PM
NightKids's Avatar
Default LS questions
I wanna put crower stage 3 cams into my stock ls motor is this a good idea? Is there anything better? Do I need to change anything else from stock outside what the kit comes with? Thanks
Old Jun 3, 2003 | 05:57 PM
VXpride's Avatar
Default Re: LS questions (NightKids)
you should get some better valve springs / retainers at least.
Old Jun 3, 2003 | 07:16 PM
ls95hatch's Avatar
you should read crowers recomnedation. stage 3's usually say you need to/should replace oem valve springs, valves, retainers
Old Jun 3, 2003 | 07:20 PM
Kataku2K3's Avatar
Default Re: LS questions (ls95hatch)
My first opinion here would be to say **** buying nonVTEC cam's and just pop a VTEC head on there... Tho the LSVTEC will run more in the long run you'll like the gains a lot more... I don't work with Crower in the VTEC world because I am simply just not happy from what we've seen... If you do plan to use such an aggressive cam as those, I would look into headwork even on the PR4/74/75 nonVTEC heads... Latez
4DR_EK
May 10, 2010 09:43 PM
93LsVx
Mar 6, 2009 06:40 AM
phaphon
Feb 10, 2009 12:55 PM
4drDA
Apr 26, 2006 05:07 PM
91ls-v
May 20, 2004 03:49 AM
