Intake Manifold and Throttle Body
Old Jun 3, 2003 | 02:16 PM
steve_s's Avatar
Default Intake Manifold and Throttle Body
What is the best Intake Manifold and Throttle body that I can fit on my d16z6. Wether it is aftermarket or just one from another honda engine. Your input would be appreciated, thanks...
Old Jun 3, 2003 | 03:38 PM
silos's Avatar
Default Re: Intake Manifold and Throttle Body (steve_s)
ah, if you pick up a b-series t/b, make sure the map sensors are in place and it's around the same year. b'cuz i got a t/b for free from an earlier b-series non obd-1 and my map sensor had nowhere to plug into. i had vacuum probs and was throw codes like crazy.. i dunno if this was very helpful. atleast i didnt pay for the t/b..its a great paper weight now.. hehe
Old Jun 3, 2003 | 03:40 PM
Dancing is Forbidden's Avatar
Default Re: Intake Manifold and Throttle Body (silos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silos &raquo;</TD></TR><TR><TD CLASS="quote">ah, if you pick up a b-series t/b, make sure the map sensors are in place and it's around the same year. b'cuz i got a t/b for free from an earlier b-series non obd-1 and my map sensor had nowhere to plug into. i had vacuum probs and was throw codes like crazy.. i dunno if this was very helpful. atleast i didnt pay for the t/b..its a great paper weight now.. hehe</TD></TR></TABLE>Dont listen to that. You can just plug your map sensor that you have already in the car. Just plug the MAP sensor in where the nonOBD MAP sensor plugged into. You could use a ITR t/b and a y8 manifold, that would be awesome.
Old Jun 3, 2003 | 03:42 PM
steve_s's Avatar
Default Re: Intake Manifold and Throttle Body (EF9_SiR)
Is all that stuff bolt on? or does it require modifications?
What kind of difference will I see with this stuff on?
Old Jun 3, 2003 | 03:52 PM
well i just did a post on this a few days ago and I was told that you will only gain throttle response unless you have fi or a lot of head work done. Also, if you use a Bseries throttle body you have to port match that to the intake manifold. That is where you make the hole on the intake mani the same size as the throttle body. Ya heard?!
Old Jun 4, 2003 | 02:39 PM
mooseknuckle's Avatar
Next week im putting on y8 intake manifold and a gsr tb on my y7. I'll prolly post
some pics and little tech after I do it. It was seriously isn't a big deal. Just have
a dremel at hand.
Drew
Old Jun 4, 2003 | 02:47 PM
Default Re: Intake Manifold and Throttle Body (mooseknuckle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mooseknuckle &raquo;</TD></TR><TR><TD CLASS="quote">Next week im putting on y8 intake manifold and a gsr tb on my y7. I'll prolly post
a dremel at hand.
Drew
</TD></TR></TABLE>Are you going to use the dremel to port match the manifold?
Old Jun 4, 2003 | 03:55 PM
JCracer723's Avatar
im on the same road. and yes im going to use the dremmel to port the manifold.
Old Jun 4, 2003 | 04:32 PM
tek_civic's Avatar
Default Re: Intake Manifold and Throttle Body (JCracer723)
how much power is to be had by switching to a y8 manni from a z6?
Old Jun 4, 2003 | 04:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Are you going to use the dremel to port match the manifold?</TD></TR></TABLE>
Sure am. The GSR TB is a 60mm. The y8 tb is a 56mm
Old Jun 4, 2003 | 04:58 PM
tek_civic's Avatar
really? i thought the gsr TBs were 58mm but i can't really remember, isn't there some modifacation needed to get the throttle cable to operate the throttle rotor correctly? something about how the d and b series rotate differently?
Old Jun 4, 2003 | 05:40 PM
Default Re: Intake Manifold and Throttle Body (tek_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic &raquo;</TD></TR><TR><TD CLASS="quote">really? i thought the gsr TBs were 58mm but i can't really remember, isn't there some modifacation needed to get the throttle cable to operate the throttle rotor correctly? something about how the d and b series rotate differently?</TD></TR></TABLE>
I know as a fact the gsr tb is 60mm. I havn't heard about throttle cable problems,
but i guess we'll see next week when i do it.
But ya, if anyone has experience with this and had a throttle prob lemme know.
Drew
Old Jun 4, 2003 | 06:08 PM
what bit are you using on the dremel? Got a part number?
Old Jun 4, 2003 | 06:15 PM
not sure yet. Im borrowing my friends. I'll tell ya when pick it up in the next
couple of days. Nothing to big prolly.
Drew
Old Jun 4, 2003 | 06:38 PM
tommyboy's Avatar
I was waiting for the shunk2 intake mani to come out for the D-series but its taking forever. I have access to a Y8 intake manifold just need the GSR throttle body. If anyone has a spare feel free to shoot me an PM. Thanks.
-Tom
Takumi Fujiwara
Jul 20, 2007 08:50 AM
jdmhatch3
Apr 26, 2007 09:30 AM
(JON)
Jul 7, 2004 05:00 AM
NOSed_b18b
Oct 15, 2003 06:25 PM
