96-00 EJ6 exhaust question
Old Jun 2, 2003 | 07:13 PM
Filliam H. Muffman's Avatar
Default 96-00 EJ6 exhaust question
When i buy a fullcat-back for my EJ6, it will bolt up. But, the cat for my car is under the hood. so when i swap the motor, will the exhaust still bolt up with if i put a cat there ? or will i need to get the exhaust cut or something? i was curious about this for a while. i was thinking maybe because the cat was under the hood, the exhaust mani goes a longer distance before hitting the exhaust piping, as opposed to say a d16y8, or a b series swap.?
Old Jun 2, 2003 | 09:11 PM
ruthless013's Avatar
Default Re: 96-00 EJ6 exhaust question (JUN EK9)
if you have an ex coupe, the exhaust will bolt up witha b16 no prob. i went from ex exhaust connected to ex motor, then to ex exhaust connected to si motor (b16a2), then si exhaust to si motor. what i mean is, any exhaust for ex/si will be fine.
if you have a dx/cx/hx etc, i'd wait to buy exhaust until after you have motor.
Old Jun 2, 2003 | 09:32 PM
RickChew's Avatar
Default Re: 96-00 EJ6 exhaust question (ruthless013)
If you have a D16Y7{ie DX} (which im guessing you do) you will have to buy an exhaust made to fit that engine. I would suggest going ahead and getting an exhaust for the EX/SI and then just putting the factory exhaust manifold (header) from an EX on your car. That way if you ever swap your engines you can keep you exhaust. Rick
yggy123
Honda Accord 2016- 2017
Sep 10, 2017 02:43 PM
ELIT3
Sep 25, 2009 02:39 PM
redDAinteg
Sep 3, 2005 05:56 PM
gutted-dx
Jul 28, 2004 04:13 PM
