buzz in exhaust, what causes it??
Old Jun 2, 2003 | 06:09 PM
neilff's Avatar
Default buzz in exhaust, what causes it??
i got my magnaflow muffler on today, it is buzzy over 3k during WOT
i am running 2.25" pipe from cat back with a new hi flow cat. i have a flex pipe connecting the cat and header. theres a resonator installed between the cat and the muffler twist in the rear around the gas tank. it is all crush bent piping. the muffler is a offset / centre muffler, stainless steel. 4"x7" or something is the name. just a universal muffler.
i kinda jumped the gun on getting my exhaust because this past weekend it broke at the cat and at the intermediate pipe. so everything is new header back. someone told me mandrel bent piping would fix this, or a longer resonator.. any help guys? why is the noise raspy?
Old Jun 2, 2003 | 06:13 PM
B16b2b's Avatar
Default Re: buzz in exhaust, what causes it?? (neilff)
i think it just depends on the exhaust. i have a buddy club spec3, and it gets a little buzzy, too. BTW, it's large diameter and mandrel bent.
Old Jun 2, 2003 | 06:24 PM
Kamin's Avatar
Default Re: buzz in exhaust, what causes it?? (B16b2b)
you need a resonator.
Old Jun 2, 2003 | 06:26 PM
neilff's Avatar
Default Re: buzz in exhaust, what causes it?? (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">you need a resonator.</TD></TR></TABLE>
read b4 u post.. i already have one.
Old Jun 2, 2003 | 06:32 PM
yaya's Avatar
OWND roflmao
OH!!!!!
buzz = resonation
get another resonator =P
Old Jun 2, 2003 | 06:33 PM
Kamin's Avatar
Default Re: buzz in exhaust, what causes it?? (yayaRl337)
you need a bigger/better resonator.
some exhausts have to use 2 because of shitty mufflers.
Old Jun 2, 2003 | 06:39 PM
poison's Avatar
The noise you hear is called fart. This is vibration of the exhaust when you poop it out.
Get a bigger resonator and you'll be fine to lessen the vibration.
Old Jun 2, 2003 | 06:50 PM
rodrez.'s Avatar
Quote: someone told me mandrel bent piping would fix this, or a longer resonator..
Mandrel bent piping will not make a noticeable difference in sound, but a bigger resonator will
Old Jun 2, 2003 | 06:58 PM
neilff's Avatar
Default Re: buzz in exhaust, what causes it?? (rodrez)
okay, thx for the help
i thought i was safe with the single resonator
but i guess i will search for a larger / better one..
can anyone suggest a specific type / dimension?
also, will it be able to replace the one in there right now? its welded in on both sides and will it change the sound dramaticly (volume & tone) or just drop the buzzing?
Old Jun 2, 2003 | 07:00 PM
Echo7847's Avatar
like a 22-24" long resonator should be good for ya.
Old Jun 2, 2003 | 07:01 PM
neilff's Avatar
i would estimate that i have a 17" resonator..
so the same size as my c*ck give or take a few inches
how big should i go?
Modified by neilff at 8:15 PM 6/2/2003
Old Jun 2, 2003 | 07:06 PM
Si Arn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neilff &raquo;</TD></TR><TR><TD CLASS="quote">i would estimate that i have a 17" resonator..
how big should i go?</TD></TR></TABLE>
did ya line up your cack and your resonator? Dont get any metal slivers doin that...
Old Jun 2, 2003 | 07:15 PM
neilff's Avatar
Default Re: buzz in exhaust, what causes it?? (Si Arn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Arn &raquo;</TD></TR><TR><TD CLASS="quote">
did ya line up your cack and your resonator? Dont get any metal slivers doin that...</TD></TR></TABLE>
nah man, its all new pipe
nice and tig welded..
Old Jun 3, 2003 | 07:51 AM
rodrez.'s Avatar
Modified by neilff at 8:15 PM 6/2/2003</TD></TR></TABLE>
WTF?? Hahahahaha
Old Jun 3, 2003 | 07:58 AM
Ricey McRicerton's Avatar
Id suggest a 22-24 inch resonator...like said above!
Old Jun 3, 2003 | 08:25 AM
brent_G's Avatar
Default Re: buzz in exhaust, what causes it?? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">The noise you hear is called fart. This is vibration of the exhaust when you poop it out.
Get a bigger resonator and you'll be fine to lessen the vibration.</TD></TR></TABLE>
there is a difference between fart and buzz...my world sport had a small buzz to it...but my es has a smooth tone...my old N1 was fart!
Old Jun 3, 2003 | 08:32 AM
teal_dx's Avatar
i had a pin hold in mid mid ipe that was making the car buz at WOT. went away when i replaced the mid pipe. i know yours is all new but might want to double check the clamps so they are tight enough
Old Jun 3, 2003 | 08:37 AM
SOHC_MShue's Avatar
Default Re: buzz in exhaust, what causes it?? (teal_dx)
my es oval with 2.25" piping and resonator buzzes sometimes. It doesn't do it all the time though...i think just when i have been driving it a whole lot. If i let it sit for a while it will sound better.
mdtsdca
Sep 22, 2012 06:42 PM
honda95civic
Welding / Fabrication
Jun 9, 2005 10:14 AM
Bspec18
May 27, 2003 09:14 PM
acme
Sep 22, 2002 10:31 PM
B19CivicHB
Dec 6, 2001 10:50 AM
