LSvtec build and reliability?
Old Jun 2, 2003 | 05:39 PM
rice_classic's Avatar
Default LSvtec build and reliability?
I am looking at building an LSvtec as a project and I would be using the kit that is sold here on honda tech https://honda-tech.com/zerothread?id=420826. I would be using the pistons out my b16 with a new ring set. I would also be using GSR oil pump, water pump, and timing belt. I would also be balancing the Crankshaft.
I would be reving this motor and would like to see it above 8k.
Question: Is the Block Girdle from a b18c1 the best one to use and is it possible to install Piston Squirters on the LS block.
Question: If I take an LSvtec with this setup (including girdle) above 8k will it decrease it's overall reliability significantly?
Old Jun 2, 2003 | 06:00 PM
turbodsmpower's Avatar
Default Re: LSvtec build and reliability? (rice_classic)
the answer to your questions are yes and yes anything you rev out to 8k will become less and less reliable and more wear. will a motor last 50-60k w/ revving to 8k on numerous occasion if maintained i dont see why not if your looking for that kind of mileage out of it.
Everyone will tell you its all on how its built. I love my setup and w/ the right patience it will be well worth while investment. Here is my setup i have over 2500 miles on it drive it to work everyday and race it hard at the track quite often at least 2times a month when i see the need after new parts or something new i adjusted. So its all up to you. Ive just done whats been proven to work w/ a good combo anything is possible
https://honda-tech.com/zero...age=1
Old Jun 3, 2003 | 11:53 AM
Default Re: LSvtec build and reliability? (turbodsmpower)
Thank you for your reply. Infact, thank you very much.
Rude and immature responses and people yelling "search" are far to abundant on H-T nowadays.
I appreciate the help.
nota-eg
Jun 15, 2006 10:26 AM
Sloshy
May 23, 2006 07:48 AM
DC-2uned
Mar 23, 2006 07:43 AM
all-go-ls
Jul 31, 2005 04:04 PM
dfoxengr
Apr 8, 2005 06:04 AM
