How Do You Do Your Compression Tests?
Old Jun 2, 2003 | 02:16 PM
LudeyKrus's Avatar
Default How Do You Do Your Compression Tests?
I always thought it was four revolutions, and it was easy to do that a while back b/c my battery was a bit weak. But now it cranks pretty darn fast, and the longer I let it crank, the higher the reading i get. So, should i stick w/ a quick crank, or crank it for like 10 seconds to get the highest reading?
Old Jun 2, 2003 | 02:22 PM
ALTERED4's Avatar
i let the motor crank until the needle on the tester will not go up anymore...
the tester will reach a point where no matter how much you turn the motor, the compression reading will not go up any higher...
Old Jun 3, 2003 | 03:32 PM
LudeyKrus's Avatar
kool; i'll try that next time. only thing is i tried that and i got like 200, but i know my rings are bad...anyone else got any info?
MRturbo
Feb 20, 2008 06:25 PM
viciousvisionslarry
Dec 7, 2006 09:08 PM
JDM_ITR
19
Aug 20, 2003 04:44 PM
bossman032
33
Jun 5, 2003 07:41 PM
Loveless
Mar 31, 2003 10:07 PM
