got a nasty vibration in the car...
Old Jun 2, 2003 | 03:34 AM
KGAccord's Avatar
Default got a nasty vibration in the car...
i rebalanced the tires it doesn't seem like that. i have had a few people look at it and they think it's a warped flywheel or maybe the intermediate shaft/axles. it seems to do under load between 50-60 mph. letting off the gas or depressing the clutch it goes away. any ideas.
Old Jun 2, 2003 | 06:59 AM
sslude's Avatar
Default Re: got a nasty vibration in the car... (KGAccord)
maybe what your friends say, or fuel delivery?
Old Jun 2, 2003 | 07:07 AM
im_the_teacher's Avatar
Default Re: got a nasty vibration in the car... (sslude)
your cv joint is ***, replace it
Old Jun 2, 2003 | 07:15 AM
rjr162's Avatar
Default Re: got a nasty vibration in the car... (im_the_teacher)
It could be a bent rim. I know usually they don't balance, but I've seen them balance before and still affect the ride which makes sense because it is bent after all
Old Jun 2, 2003 | 07:38 AM
BlackPrelude93's Avatar
i have a slight vibration in my lude, no bent rims, changed both cv's, balance tires, aligment, new brakes rotors....still shakes...i still don't know what it is,
Old Jun 2, 2003 | 07:42 AM
KGAccord's Avatar
Default Re: got a nasty vibration in the car... (rjr162)
my rims should be fine since i'm runnning stock 15s, but my tires need replacing and i do have high spots on my front tires. i haven't got around to switching them out to see if thats the problem. we put the car on the lift and the vibration was still their without the wheels touching the ground. the axles themselves are remans, but are only a year. that's still a possibility although they make no noise in hard left\right turns. i guess a bearing inside could be messed.
some more info..the vibration shakes the whole cars front end, not the steering wheel. if i had to guess which side it feels like it's coming from, the passenger side. it also makes the speedo shake under hard acceleration in 3rd at those speeds.
Sephro's Avatar
Default Re: (BlackPrelude93)
Balancer shafts off by a few teeth??
Also that could be your tie rod ends. If they are loose they would cause some shaking...
Old Jun 2, 2003 | 09:03 AM
KGAccord's Avatar
Default Re: (Sephro)
yeah i should check the tie rods too, jack up the car and see if the wheel has side to movement right.
Old Jun 2, 2003 | 10:31 AM
Sephro's Avatar
Default Re: (KGAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KGAccord &raquo;</TD></TR><TR><TD CLASS="quote">yeah i should check the tie rods too, jack up the car and see if the wheel has side to movement right.
That will work if you don't have both front tires off the ground. if you pull the wheel off you should be able to grab them and see if they have any excess movement.
miguey310
25
May 31, 2010 05:44 AM
DC2SIR-G
Mar 11, 2006 01:55 PM
dellanooch
Jul 7, 2004 07:01 PM
00WhiteEKy
19
Feb 11, 2004 11:36 AM
TheSwift1
May 3, 2002 07:35 PM
