CODE 7
Old Jul 16, 2001 | 03:30 PM
Just2Fast's Avatar
Default CODE 7
Ok here's the problem the car is a LS Turbo and it keeps twrowing a code 7 (throtle possition sensor i think) Cant seem to get rid of it, please help.
Old Jul 16, 2001 | 04:30 PM
raene's Avatar
Default Re: CODE 7 (Just2Fast)
Is your throttle cable on too tight? Have you tried replacing the TPS?
Old Jul 16, 2001 | 07:37 PM
Just2Fast's Avatar
Default Re: CODE 7 (raeneshadow)
yes the TPS was replaced and the same thing happened. But the cable was tightened before. Could a tight throtle cable be causing a CEL
Old Jul 17, 2001 | 12:11 PM
raene's Avatar
I think I can get my car to throw a TPS code by trying to rev it when I'm starting it. I did that by accident once, so I'd think a too-tight cable might do it too.
A code 7 is also sometimes thrown when there's a problem with the MAP sensor... doublecheck all the vacuum lines are tight and snug, and if that doesn't work, try swapping your MAP with a known-good unit.
HondaMan2380
Mar 26, 2012 11:08 AM
90AcuraIntegra04
Aug 7, 2005 05:04 PM
S2KP
Oct 7, 2003 10:15 PM
synergy004
Jul 5, 2001 07:10 PM
