LCA question
Old Jun 1, 2003 | 07:55 PM
GReddy SI's Avatar
Default LCA question
I need sway bars on my vx because this thing is scary going at high speeds and the car is not too safe. I can lose control of it too easy and not safe to drive around like this. so my question is could i get a 92-95 lca's from a si hb or ex and put them on my vx and then add some aftermarket sway bars on the front and rear?
Old Jun 1, 2003 | 08:07 PM
SpoonEK2's Avatar
Default Re: LCA question (GReddy SI)
yes
Old Jun 1, 2003 | 08:12 PM
EX R8ED's Avatar
not on the rears, for the rears you have to get 92-95 EX sedan LCA's or Teg ones, or Del sol VTEC ones....
Old Jun 1, 2003 | 08:13 PM
piscorpio's Avatar
You don't necessarily need the LCA's from an EX or Si. I have a Suspension Techniques rear sway bar that works with any 92-00 Civic, since it does not use stock mounting locations. Did the 92-95 EX Civics have rear sway bars at all (I know the 96-00 don't)?
Old Jun 1, 2003 | 09:16 PM
GReddy SI's Avatar
Default Re: LCA question (SpoonEK2)
anyone really sure about this?
Old Jun 1, 2003 | 09:38 PM
Touch's Avatar
92-95 civics don't have rear sways. sure of it.
my bad... forgot to say that. about the sedans.
Modified by Touch at 2:15 AM 6/2/2003
Old Jun 1, 2003 | 10:05 PM
TurboBumblBee's Avatar
Default Re: LCA question (Touch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touch &raquo;</TD></TR><TR><TD CLASS="quote">92-95 civics don't have rear sways. sure of it.</TD></TR></TABLE>
92-95 coupes and hatches did not have rear sway bars.. 92-95 civic sedans did.. if you want to put a rear sway bar on your VX i would get a set of 94+ integra rear lca and you can bolt up a gsr or itr sway bar... btw, i love my JDM ITR rear sway bar..
Old Jun 1, 2003 | 10:29 PM
elwood's Avatar
Default Re: LCA question (Hybrid95CivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid95CivicEX &raquo;</TD></TR><TR><TD CLASS="quote">
92-95 coupes and hatches did not have rear sway bars.. 92-95 civic sedans did.. if you want to put a rear sway bar on your VX i would get a set of 94+ integra rear lca and you can bolt up a gsr or itr sway bar... btw, i love my JDM ITR rear sway bar.. </TD></TR></TABLE>
Not all 4dr's, just the ex's. If your going about it the cheap way you minght
want to get a 14mm gsr rear bar and you wont have to buy the beaks kit.
Old Jun 1, 2003 | 11:37 PM
GReddy SI's Avatar
Default Re: LCA question (d15dude)
how much do 94+lca run for?
Old Jun 2, 2003 | 12:09 AM
EGTeK's Avatar
dont get the wrong idea about sways though. a good setup for you would be a 19mm ex front / gsr lca + 14mm gsr rear / teg lca.
22mm rear isnt fun at high speeds either, even with a 24mm front.
= 92 teg lcas should be anywhere from 60-100 depending on where you get them from
Old Jun 2, 2003 | 12:24 AM
eg6sir-s's Avatar
if you need the front... i have the suspension techniques front sway bar for 92-95 civics with no front sway bar for $75+shipping(if required). what is your location?
h-t member kgrcr1 has the rear suspension techniques sway bar for sale.
p m me if you have any further questions.
Ukrainamese
Suspension & Brakes
May 15, 2007 09:05 AM
allenp
14
Aug 3, 2006 01:46 PM
CRXdan
Mar 4, 2006 06:43 PM
mike93eh
Feb 9, 2004 04:21 PM
DerangedEG
17
Apr 15, 2003 07:31 PM
