SOHC turbo ....
ok well i know most of the stuff that is needed to build my 1.6 sohc vtec.. but i get a lil confused between some of the parts... If i build it i am most likely going to purchase the Greddy kit...... what is not included in the kit that i will need
-boost controller
-turbo timer
-gauges
it comes with the Blue Box, but a lot of people ditch it and go with a better fuel management; although some people have put down nice numbers using the box... what kind of build are you going to do? mild or extreme? Your goals? good luck and check out the FI forum...There's plenty of information in there to keep you busy for hours...
-turbo timer
-gauges
You probably won't need new injectors unless you turn up the boost. If you get past 180whp or so, then you should start looking at some 310cc or larger (depending on goals). You won't need a fuel rail unless you are looking for 250+hp. Hondata would be a good way to go, but the Apexi VAFC may also get the job done. Just depends on your goals. You should also plan on getting an upgraded in-tank fuel pump.
CivicRaping
Apr 28, 2005 11:22 AM
