Checking tranny fluid in D16 and changing it?
Old Jun 1, 2003 | 05:57 PM
spencedogg's Avatar
Default Checking tranny fluid in D16 and changing it?
Hey guys i need help with checking the tranny fluid how do you do this and how do you change the fluid in this 98 ex motor
Old Jun 1, 2003 | 06:14 PM
Lord Helmet's Avatar
Default Re: Checking tranny fluid in D16 and changing it? (spencedogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spencedogg &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys i need help with checking the tranny fluid how do you do this and how do you change the fluid in this 98 ex motor</TD></TR></TABLE>
if this is a 5spd:
you check by looking at the tranny plug which sits near the side of tranny on the top. take the plug off and put your finger in the hole. if you feel the tranny fluid at the hole it's good. if not just add until it fills up to the hole. you change it just like you would with a oil change, except you don't replace a oil filter. there's a drain plug near the bottom of the tranny, you'll need a 3/8 drive rachet to remove that plug. takes about less then a 2 quarts to fill it up.
Old Jun 1, 2003 | 06:18 PM
spencedogg's Avatar
thanks man
Old Jun 1, 2003 | 06:23 PM
Default Re: (spencedogg)
no problem
KnightX
Mar 15, 2007 01:17 PM
Adrian G. Aka JDMonkey
Oct 18, 2006 04:17 PM
pelotudo
Jul 21, 2002 02:33 AM
96Prelord
Jun 5, 2002 07:21 PM
hb_racer
Mar 17, 2002 06:27 PM
