Stripped the upper tranny mount bolt holes. Now what?????
Old Jun 1, 2003 | 05:06 PM
JV's Avatar
JV
Who?
Default Stripped the upper tranny mount bolt holes. Now what?????
Pulled my tranny today to install the new clutch. Everything went smooth until i reinstalled the upper tranny mount bolts.
I stripped out the 2 holes below:
What can i do to fix these? Helicoil maybe?
Anybody have any suggestions?
Thanks, JV
Old Jun 1, 2003 | 05:10 PM
dirtySOHC's's Avatar
Default Re: Stripped the upper tranny mount bolt holes. Now what????? (JV)
is there any chance you can re-thread it?
Old Jun 1, 2003 | 05:12 PM
Fuster_Cluck's Avatar
Tap & Die.
They (one of the 2) are used to fix threads
Try a search on "stripped bolt" or something along that line and you should get some info on what I am talking about.
Old Jun 1, 2003 | 05:16 PM
Nextelbuddy's Avatar
this happened to my friend a while back is actually broke the holes apart to where u couldnt even put a bolt in he ended up getting a tranny case for 75 bux and swapping the tranny guts into it.
Old Jun 1, 2003 | 05:17 PM
tominos's Avatar
helicoil should do the trick
Old Jun 1, 2003 | 05:18 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Stripped the upper tranny mount bolt holes. Now what????? (nextelbuddy)
you're gonna have to tap it out larger, instal helacoil, and then use your old bolts...
how did you strip those??? Diddn't you have a jack under the tranny while you were loosening them???
Healacoil is your best bet and easiest bet now
Old Jun 1, 2003 | 05:20 PM
EKweezy's Avatar
i say put heli coil, i stripped my block{where the head bolts go} and the machine shop recomends putting heli coil, its better then rethreading aluminum he says, but i don't know, go talk to your machine shop
Old Jun 1, 2003 | 05:29 PM
JV's Avatar
JV
Who?
Default Re: Stripped the upper tranny mount bolt holes. Now what????? (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">you're gonna have to tap it out larger, instal helacoil, and then use your old bolts... </TD></TR></TABLE>
That's what i thought. Just wanted some varification...
how did you strip those??? Diddn't you have a jack under the tranny while you were loosening them???</TD></TR></TABLE>
I stripped them using an air ratchet ( on me) while i was reinstalling them...
Installation tip of the day:
<FONT SIZE="25">Handtighten these bolts or you'll end up like me!!!!</FONT>
Old Jun 1, 2003 | 05:31 PM
Evs-One's Avatar
Solbros Owns Me
HAHA...at least just turn them in with your hand until the threads match up
Good luck finding a place open today to get your parts...especially at 6:30
NAallthewayEM1
Jul 13, 2010 03:00 PM
spladam02
Dec 8, 2002 06:42 PM
Traymack1
Sep 17, 2002 07:57 PM
ragejed
Sep 8, 2002 04:33 PM
Turbohatch
Oct 26, 2001 12:25 PM
