Brake Pressure problems after rear disk conversion
Old Jun 1, 2003 | 03:20 PM
jdkindle's Avatar
Default Brake Pressure problems after rear disk conversion
I have plenty of fluid and have bled them 3 or 4 times.........but when I try to stop, I have to press the pedal all the way down and it stops slowly......when I get into fast, they lock up
any suggestions?
Thanks!
Old Jun 1, 2003 | 03:55 PM
litlekikr's Avatar
Default Re: Brake Pressure problems after rear disk conversion (jdkindle)
did you switch over your proportioning valve to one that came from a 4 wheel disc 'teg or crx? I don't know if both the rear drum or rear disc crx's came w/ the same valve and mastercylinder but maybe that'll fix your problem. Are you leaking fluid anywhere?
Old Jun 1, 2003 | 04:44 PM
jdkindle's Avatar
Default Re: Brake Pressure problems after rear disk conversion (litlekikr)
Im not leaking fluid, but I left the master cylinder alone, so I will have to play with that I guess
the donor car was a 91 CRX Si going to a 89 CRX DX FYI
Old Apr 17, 2006 | 11:06 PM
NZDelsoldude's Avatar
I'm having a similar problem after a conversion on my eg and desperatly need help. thing is my brakes won't even bleed now. No pressure is building up.
Old Apr 18, 2006 | 03:14 AM
mahatma's Avatar
Default Re: Brake Pressure problems after rear disk conversion (NZDelsoldude)
^ Props for searching
It's got to be either a fluid leak at the rear, or a MC problem. Bench bleed the MC!! I bet it's mad air in your system.....
Old Apr 18, 2006 | 03:58 AM
Cory man's Avatar
Default Re: Brake Pressure problems after rear disk conversion (mahatma)
I highly recommend swapping proportioning valves with a rear disc integra or crx. I would try this first before I throw other parts at it.
Old Apr 20, 2006 | 09:26 PM
Default Re: Brake Pressure problems after rear disk conversion (Cory man)
cheers guys I'll perservere. I had a spare 30-40 prop valve which i've now put in as well.
Old Apr 20, 2006 | 10:38 PM
fourthgenhatchB17's Avatar
If the prop valve was working correctly before you did the swap, then its most likely NOT the cause. Hell, im still running on my DX valve and Ive had rear disc for years!
Did u let the system completely drain when u did the swap?
Old Apr 20, 2006 | 10:41 PM
Tyson's Avatar
this has nothing to do with the prop valve.
youve got air in your system still or you have a leak. simple as that.
Old Apr 20, 2006 | 11:39 PM
Default Re: Brake Pressure problems after rear disk conversion (fourthgenhatchB17)
It was actually odd because when I undid the rear brake lines no fluid came out. After the install I used a vacume bleeder and fluid only came out of one side. Now i can't even bleed the front brakes.
Old Apr 21, 2006 | 10:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NZDelsoldude &raquo;</TD></TR><TR><TD CLASS="quote">It was actually odd because when I undid the rear brake lines no fluid came out. After the install I used a vacume bleeder and fluid only came out of one side. Now i can't even bleed the front brakes.</TD></TR></TABLE>
Check the bleeder valve itself for dirt/crud that has built up inside of it. That dirt doesnt allow the fluid to come out when u crack it open.
Old Apr 24, 2006 | 06:49 PM
thanks for all your help everyone. I took my car to the mechanic in the end. He blew out the system with compressed air and found that one of the lines had a nick out of the flared end and the piece was causing a blockage. So he replaced the line and all is well. (It was one of my home made lines btw not a honda one)
delsizzle1
15
Feb 15, 2012 09:37 PM
JonLeeEK
18
Dec 22, 2008 07:18 AM
rdssk8rcs1
Mar 31, 2008 04:09 AM
JDM_SOHC
21
Dec 11, 2006 09:12 AM
b18c-ivic_gsR
24
Nov 1, 2006 06:08 PM
