Proportioning valve help..
Old Jun 1, 2003 | 11:47 AM
ntrinsik's Avatar
Default Proportioning valve help..
Okay, I'm fixing and replacing some stuff from my rear disc swap I did a year ago (new SS lines, SI parking brake lines, new pads/rotors) and I'm trying to figure out if I need a new proportioning valve. I've checked part numbers on hondaautomotiveparts and this is what I found:
'98 3DR DX
22522 004 1 VALVE, PROPORTIONING NO COLOR 97.93 73.45
'99 2DR SI
'00 2DR SI
220473 004 VALVE, PROPORTIONING NO COLOR 97.93 73.45
From what I can see.. mine and the '99 SI one are the same, but both are different from the '00 SI. I'm wondering if anyone happens to know if I need to change it out.
Old Jun 1, 2003 | 11:49 AM
andrew dc's Avatar
Default Re: Proportioning valve help.. (ntrinsik)
they are all the same... DA or DC
I have 8 40/40 prop valves
50 shipped
Old Jun 1, 2003 | 12:59 PM
ntrinsik's Avatar
Default Re: Proportioning valve help.. (CRX25)
I see. So I guess I don't need to change mine out. Thanks.
Old Jun 1, 2003 | 02:16 PM
andrew dc's Avatar
make sure it has a 4040 stamp on it
Old Jun 14, 2003 | 04:54 PM
jimsterli's Avatar
How about the hard lines? The lines running from the master cylinder to the prop valve and prop valve to the brakes.
Can the original lines be reused? or do those have to be swapped out too with the new prop valve and master cylinder? For instance ... 99-00 Si into a 96-00 DX.
Thanks.
JLi
dubs97integ
Aug 21, 2009 11:01 AM
Viorent Grip! EG
Oct 13, 2006 09:56 AM
B18C5 EH
Dec 11, 2004 12:59 PM
Jonathan_ED3
Mar 24, 2004 02:50 PM
99civic_exSB
11
Jul 3, 2003 07:03 AM
