Recommended throttle body?
Old May 31, 2003 | 08:12 PM
Crono139's Avatar
Default Recommended throttle body?
What brand/bore size throttle body would you recommend? I will need a good one in the near future when I get a dual stage intake manifold. Any help would be appreciated.
Old May 31, 2003 | 08:44 PM
ViZ's Avatar
ViZ
Default Re: Recommended throttle body? (Crono139)
ericks is a good TB
Old Jun 1, 2003 | 12:22 PM
93ludeSi's Avatar
JG makes a nice one, i think its actually JG eldelbrock (sp) now
Old Jun 1, 2003 | 01:30 PM
Keith's Avatar
Get an S2000 TB. In stock trim it's 66mm (4 mm bigger than the H22 one). I had mine P & P to 69mm.
Old Jun 1, 2003 | 01:42 PM
optikal_blitz's Avatar
what type of performance gains do you get from upgrading to, say, an s2000 tb? better response, increased gas milage, hp?
Old Jun 1, 2003 | 01:47 PM
Furry in your eye
Guest
Posts: n/a
Default Re: (NatakuBlitz)
what do you have done to your engine? the stock throttle body is good to around 200-205hp. id worry about cams and intake manifold before a throttle body. all your gona do is kill the bottom end and loose your throttle responce
Old Jun 1, 2003 | 02:32 PM
juicedh22's Avatar
Default Re: (Furry in your eye)
Reguarding this, I have a JG TB, and soon as I put it on, I am throwing code 7... (Throttle Angle) anyone have any idea how I can remedy this problem?
Old Jun 1, 2003 | 03:20 PM
93ludeSi's Avatar
that might be the throttle position sensor
Old Jun 1, 2003 | 03:45 PM
juicedh22's Avatar
Default Re: (93ludeSi)
yea, thats what Im finding out from a very looong and not-so-fun google search. So it says the most probable cause is a defective sensor, or reading too hight or too low, but the JG TB comes with a new tps sensor attached so i don't think it is that, especially since i got the same code w/ a different TB on it.
Also, I only get the code when I am laying on the gas really had, (heavy accel.) I may try adjusting the throttle cable... I dunno, im clueless....
Old Jun 2, 2003 | 08:55 PM
tek_civic's Avatar
Default Re: (juicedh22)
ya make sure that there is a little play in the throttle cable at off throttle and at WOT. there should be a little play if not loosen it a little bit and see what happens. if its too tight you can snap a cable.
Old Jun 3, 2003 | 02:12 AM
TimeRacer's Avatar
I have a S2000 TB that has been bored out to 69mm intake 64mm manifold that I'd be willing to part with. PM me if you're interested.
DC5mike
Dec 1, 2007 05:15 PM
allnaturalb16
Sep 26, 2006 02:09 PM
tegSB85
Nov 17, 2005 05:50 AM
Fink2iCe
Aug 20, 2004 10:50 AM
bryant382
Sep 14, 2003 04:14 AM
