jetting chart for 50 and 75 shot for nx Part#: 80004EFI 4CYL GASOINE EFI DIRECT-PORT(50-75-100-150-2
its 31n/18f for a 35 shot, 35/20 for 40 shot, and 41/24 for a 75shot
Edit: Wait......are you using the direct port and want the 50 and 75hp settings, or do you have the direct port kit and want to use the standard single fogger setup? If you use the direct port (as i am)....NX said to use 22/18 @10psi for a 75hp shot, and ROBY on h-t.com said to use a 22/16 at stock psi for an 80hp shot.
