1st gear pops out. why?
Old May 31, 2003 | 09:02 AM
BlVlW313's Avatar
Default 1st gear pops out. why?
i went to the track last thursday. got some pretty shitty times cause alomst every run i had my trannie would just pop out of first gear. i dropped it at like 3500 rpms and it just pops out.
i think its either:
1. new motor mounts
2. better suspension
i want to get this problem fixed so i can put down some reasonable times.
oh btw its a 01 gsr motor in a 99 civic.
Old May 31, 2003 | 12:40 PM
JMD's Avatar
JMD
Default Re: 1st gear pops out. why? (BlVlW313)
it could be a couple things. your shift linkage could be bent slightly, there are detent ***** that hold the shifter in whatever gear you select and those ***** could be screwed up. have you had any work done on your tranny lately?
Old Jun 1, 2003 | 09:42 PM
BlVlW313's Avatar
Default Re: 1st gear pops out. why? (siqcivic)
i put a dc short shifter in but that wa awhile ago. im gonna try and take it out and put the stock one in. could it be the syncros? any other advice?
Old Jun 1, 2003 | 09:46 PM
ALLMOTOR18's Avatar
its your clutch master cylinder..
check for a leak near the clutch pedal...
Old Jun 1, 2003 | 11:14 PM
Viorent GRIP!'s Avatar
nope it' your 1-2 shifter fork. it's fucked.
Old Jun 1, 2003 | 11:17 PM
97hb's Avatar
If your mounts are really messed up the motor could torque, move the shift linkage and pop it out of gear. Does this happen on normal driving or just launching?
Old Jun 2, 2003 | 12:12 AM
JDMlyfestyle's Avatar
I agree with GRIP its the shifter forks. mine use to do the same thing. thats y i got a new tranny
Old Jun 2, 2003 | 09:23 AM
ALLMOTOR18's Avatar
Default Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">I agree with GRIP its the shifter forks. mine use to do the same thing. thats y i got a new tranny
Before you go out and buy a whole new tranny check the Clutch Master Cylinder.
Mine did the same thing too and after i replaced the Clutch MC everything was good.
Old Jun 2, 2003 | 09:55 AM
BlVlW313's Avatar
this only happens when i launch at pretty high rpms if like 3500 but i think 3000 is okay. i dont think there is a leak but i will check today.
so if its the fork. i have to buy a whole new tranny or just the linkage?
Old Jun 2, 2003 | 02:47 PM
BlVlW313's Avatar
Default Re: (BlVlW313)
ttt
dc2long
Mar 27, 2011 09:47 AM
konvikt
Jan 20, 2007 08:01 PM
Bob_760
13
Sep 18, 2006 05:44 PM
msmotorsports
Oct 17, 2005 05:45 AM
crazivi3tdude
May 11, 2005 11:28 AM
