No Power in Boost. Sad and Confused.
Here's my situation. I boosted my car about 2 weeks ago. It ran beautifully. Idled great. Boost stuck me into the back of my chair. I had a few problems with I/C pipes coming off, a little white smoke at times and my SAFC wires coming loose. But all of that is done and fixed.
Car runs great now. Except I have no power in boost. I dont' have that "stick you into your chair" acceleration like I once did. I make boost. I get both readings from my boost gauge tapped from Intake Mani. and my SAFC pressure readings. I don't know what's going on. The car feels fine - like it's not losing any power anywhere else. Perhaps I've lost compression and just don't notice it @ the lower RPM's?
Anyways. This post is to see if any other member has had a similar problem. I think a compression test would yield more useful information - however I don't have a compression tester with me at the moment.
92k B18B
InlinePRO Mani
Garrett t3/t04e .48 turbine - .60 compressor
S-AFC Hack / DSM 450cc Injectors
Walbro 225lph Fuel Pump
Idles great @ 800 (+/- 20 RPM)
PS: Also just checked a thin layer of oily substance in my vacuum lines. Is this usually normal?
92k B18B
InlinePRO Mani
turn up the boost
It will feel faster again. Honestly, i know my car doesn't feel the same way it did when i first drove it. I think you jsut get used to it... Just my .02
Freshdot
Dec 15, 2010 03:11 PM
-iLLuZioN-B18C1
Mar 4, 2003 04:46 PM
