Important! oilfeed blue fitting size! HELP ASAP!
OK i have the apexi turbo kit. the blue piece that connects to the 3way T for the feed line i need to have replaced. Just bought a Russel 4AN to 1/8" NPT 90degree fitting which i thought would work. EHHH WRONG ANSWER TRY AGAIN! so guys i need to know what size it really is that screws into the brass 3way adapter! thanks, ooh and ASAP would help! and if anyone sells whatever it really is ill buy asap. what i need is 4an-? with a 90 degree bend to avoid clearance problems!
tell me what kind of turbo you have, if it's t3/4, doe it have the 4 or 5 downpipe bolts flange ?
IM me or send me an email, ex_jesuit@yahoo.com
I am 99% sure i have your adapters in stock
its an IHI AX53B60 P18 ball bearing turbocharger. it comes with the SOHC apexi turbo kit. but im looking for the fitting that goes into the 3 way T at the back of the block, not into the turbo. my instruction manual says -4an to 1/8" pt. and thats all. thanks for the help guys! i need to get this fixed!
i think i may have figured it out, tell me if this sounds like somethign that exists.
4 AN to 1/8" bspt with a 90 degree bend.
thanks.
http://store.summitracing.com/...image
thanks.
that sounds and looks about right. 1/8" BSPT to -4AN. if you can not find the 90 degree why dont you get a straight thru and switch the ends on the 'T'?
89efDUSTY
Jan 19, 2008 09:23 PM
tur3oDC4
Jul 2, 2005 02:01 AM
spoon23_JDizM AkA SpOoN20
May 16, 2004 02:18 PM
420aNT
May 10, 2004 07:13 AM
