B16 crank in GSR block...
Old Jun 1, 2003 | 10:41 AM
JDM92CX's Avatar
Default B16 crank in GSR block...
Ok guys......I'm wondering if anyone has ever did or thought about putting a B16 crank in a GSR block for the simple fact that you can rev much higher and quicker with the B16 crank cause of the R/S. Now what I'm asking is, If I put the B16 crank in the GSR block will i have to use CTR rods or even CTR aftermarket rods because it's just like using a CTR motor to begin with. So for anyone u to answer my question what's your thought's on this setup? And witht the B16 crank in the GSR block I'm almost certain that you will yeild some good torque numbers and have hella top end!
Please help...
Old Jun 1, 2003 | 01:15 PM
Cole D's Avatar
Default Re: B16 crank in GSR block... (xJDM88EF9x)
I would like to know this as well
Old Jun 1, 2003 | 01:28 PM
hpfsi's Avatar
It has been done, but honestly the only time that de-stroking a b-series motor is worthwhile is when it the r:s ratio can be improved without losing displacement. Basically with few exceptions, gains in displacement will yield more power than those produced by reving a motor higher because the r:s ratio is improved (at the expense of displacement). This is why people started making blocks with taller deck heights.
Old Jun 1, 2003 | 06:59 PM
JDM92CX's Avatar
Default Re: B16 crank in GSR block... (hpfsi)
Bump^
Old Jun 1, 2003 | 10:20 PM
tony1's Avatar
I've done it and it doesn't make **** for torque. You can make power to over 10k rpm with a gsr crank, no need to destroke it. It might be good for a road race car, but not drag.
Old Jun 2, 2003 | 05:03 AM
Lsos's Avatar
CTR engine revs only a couple hundred rpms higher than a GSR engine, and they did much more to it than just destroke it....
Old Jun 2, 2003 | 06:29 AM
earl's Avatar
Default Re: B16 crank in GSR block... (Lsos)
not a good idea but can be an expensive idea because of custom parts necessary.
Old Jun 2, 2003 | 09:09 AM
JDM92CX's Avatar
Default Re: B16 crank in GSR block... (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I've done it and it doesn't make **** for torque. You can make power to over 10k rpm with a gsr crank, no need to destroke it. It might be good for a road race car, but not drag.</TD></TR></TABLE>
What turbo did you use on this and was it fun or just a torqueless piece of junk
GermanCivic
Nov 14, 2006 08:02 PM
funvtec
May 22, 2005 09:12 AM
BLUE EH3
Oct 10, 2004 11:16 AM
turbolshatch
Jun 27, 2004 10:11 AM
granada_sun
10
Jun 20, 2003 11:18 PM
